A/T stuck in neutral help please
Old Mar 11, 2017 | 10:20 PM
  #26
guka747's Avatar
guka747
i put it back. in same position (i posted pic before)doesn't want to go in further. banged ,smashed ,hit with hummer no movement. maybe somebody give me big favor and posts his left axle picture?! how it sits in right position? automatic and manual are different. ive got manual pic already and it almost touches transmission
thank you
Old Mar 13, 2017 | 06:47 PM
  #27
guka747's Avatar
guka747
i disasembled left cv axle because it poped out couple times more, so heres posible cause;
splieners was rounded.ordered new one , i hope new part solves problem
Attached Thumbnails A/T  stuck in neutral help please-img_3204.jpg   A/T  stuck in neutral help please-img_3213.jpg
Old Mar 13, 2017 | 07:37 PM
  #28
renchjeep's Avatar
renchjeep
Looking at those pics, I would pull that shaft seal, gently use a brush to try removing all of the metal debris from the output splines inside the trans, being careful to not let much drop into the trans, and then install a new seal and shaft. Make sure the shaft goes all the way in this time, and for sure you need to check your trans fluid level. It definitely looks like some has come out.
Old Mar 13, 2017 | 07:45 PM
  #29
renchjeep's Avatar
renchjeep
My wife's 2013 Justa auto left axle shaft at trans. Plastic ring right at trans housing.
Old Mar 18, 2017 | 06:10 AM
  #30
guka747's Avatar
guka747
thank you for your pic
i received my axle finally and everything went smooth
thank you guys
Attached Thumbnails A/T  stuck in neutral help please-img_3253.jpg
Old Mar 18, 2017 | 09:29 AM
  #31
renchjeep's Avatar
renchjeep
Good news! Motor On!
