Engine Swap
Old Mar 1, 2017 | 12:13 AM
bansasn's Avatar
bansasn
Engine Swap
I am about to swap my 180k 04 S engine that is seized with a 90k 06 S engine. Anything to be aware or problems I should look out for while I'm in? Planing to change the clutch, starter and axel at the same time. Any advice is appreciated. Thanks.
Old Mar 1, 2017 | 10:32 AM
X757XVeritas's Avatar
X757XVeritas
Might as well do a supercharger service while the motor is out. The 06 is the better design, Teflon coated internals as well so that's a good find
Old Mar 1, 2017 | 10:45 AM
bansasn's Avatar
bansasn
That's an excellent idea! Thanks for pointing it out.
Old Mar 1, 2017 | 11:23 AM
gumbedamit's Avatar
gumbedamit
Are you getting the SC that came with the 06 engine, or re-using the one from the 04?
Old Mar 1, 2017 | 12:37 PM
bansasn's Avatar
bansasn
I will be using the 04 SC. The 06 engine is just a motor assembly w/o SC. Pretty much just going to transfer 04 parts to the 06.
Old Mar 1, 2017 | 01:06 PM
gumbedamit's Avatar
gumbedamit
FYI: The SC on the 04 is not Teflon coated, but it would still benefit from an oil change.
Old Mar 1, 2017 | 01:30 PM
User 41921's Avatar
User 41921
Here's a pretty good youtube series on it. I wish I had had this available to me when I swapped the motor in my buddies 05.
Old Mar 1, 2017 | 05:19 PM
bansasn's Avatar
bansasn
https://www.youtube.com/watch?v=cW3-...bOo66RG3nUfd9O
Thank you! This is a good reference!
