Trunk Will Not Open
Old Feb 22, 2017 | 02:54 PM
stiles165's Avatar
stiles165
Trunk Will Not Open
The trunk on my 2003 mini Cooper S has not been able to open since the day I bought the car. I can open by pulling the cable under the seat but it has started to drive me nuts. I think it could be some wiring issue because I bought a replacement trunk latch (where you grab to open the trunk) and that still didn't fix it. If anyone has any ideas or first hand experience that would be great. Also a wiring diagram could help. I'm pretty much out of ideas so really anything will help
Old Feb 23, 2017 | 08:55 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Did you see any corrosion anywhere when you replaced the handle? Check out the wiring harness back there for any obvious damage. You'll want to remove the trim around the rear boot and check for any type of water intrusion or corrosion. Check out this NAM thread here: https://www.northamericanmotoring.co...it-myself.html.
This guide might help if it is an electrical issue: http://www.pelicanparts.com/catalog/...mbzgft_pg3.htm and if after you do what I said above does nothing.
888.280.7799 | 6am - 5pm PST
Old Feb 23, 2017 | 09:15 AM
stiles165's Avatar
stiles165
yes I've taken all surrounding trim off and there is nothing obvious.
Old Apr 17, 2017 | 07:59 PM
stiles165's Avatar
stiles165
It turns out it was a bad ground. I hardwired the grounds from the opening mechanism to the negative battery terminal. Works like a charm now
