Missfire/zero compression issues on R53
Old Nov 3, 2016 | 07:44 AM
  #26
banyan's Avatar
banyan
Originally Posted by nkfry
This is what I'm getting at. You will have a round about answer on what the failure is and where to start your diagnostic.
I will pass along your information to the office folk and have them send you a quote Banyan. :thumsup:
Totally agree. But since 1 cylinder has no compression, the head has to come off anyways. Would I not be able to do visual on the valves, piston and cylinders to accomplish the same thing?
Old Nov 4, 2016 | 09:13 PM
  #27
PhoR53's Avatar
PhoR53
compression test only shows what is going with cylinders.... so to be more precise a leak down test can be don easily then it will show or you can hear air escaping from intake or exhaust valves.... a typical valve job will cost around 250 ish. If you are handy the head replacement job is very easy.
Old Nov 5, 2016 | 11:32 PM
  #28
banyan's Avatar
banyan
now it is clear to me. Thank you all for the clarification. I have ordered a leakdown tester. I will rent a compression tester from AUtozone.
Now my next question is regarding the cam holding tool. Is this tool neeed if all that I will be doing is replacing the head? or is this tool needed to prevent the cam from rotating while torquing the cam sprocket bolt? Any idea how to remove and install the cam sprocket without the cam holding tool? my car is R53 automatic.
Old Nov 6, 2016 | 09:02 PM
  #29
PhoR53's Avatar
PhoR53
get the tool and it costs only 33bucks on ebay. Worth every penny. It will assist you during the removal and installation procedure with ease. Torque everything to specs. Buy some engine assembly lubes. While removing the rocker arms be very gently so that the "tip" on them won't fall off
Old Nov 6, 2016 | 11:09 PM
  #30
banyan's Avatar
banyan
Good point on the cam holding tool.
I received the leakdown tester today and found that the adapter hose that came with it that connects to the spark plug hole has a Schrader valve. Is this correct? Shouldn't this adapter hose be a straight through hose? I do know that the adapter hose for a compression tester has a Schrader valve but I was not expecting the leakdown tester to have an adapter hose with a Schrader valve.
Old Nov 7, 2016 | 04:00 AM
  #31
PhoR53's Avatar
PhoR53
Yes,thread one end in the plug holes,then one will attach to air compressor (set it at 110psi). Set the pistons or cylinders at TDC (with a 1/4 extension or whatever so that you can tell its at tdc). Result of each should ve less than 10%,above means leakage
Old Nov 7, 2016 | 07:05 AM
  #32
banyan's Avatar
banyan
Thank you. I think I understand the connections but I am struggling to understand how pressurised air will flow into the cylinder when there is a Schrader valve in the hose that is connected to the plug hole.
Old Nov 7, 2016 | 07:41 AM
  #33
nkfry's Avatar
nkfry
Same dynamics of a Schrader valve in your tires; allows air in but not out.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Nov 7, 2016 | 07:57 AM
  #34
banyan's Avatar
banyan
Thank you. That is exactly my point. The Schrader valve in this case will allow air towards the meters from the cylinder. The hose adapter that came with the tester is the same as what would come with a compression tester. I am expecting the opposite.
Old Nov 7, 2016 | 11:35 AM
  #35
banyan's Avatar
banyan
just confirmed my suspicion. I have to remove the Schrader valve in order allow air pressure to go into the cylinder. I think they shipped the wrong hose adapter, but still workable after removing the schrader valve. See video below on how one guy converted a compression tester to a basic leakdown tester:
Old May 24, 2017 | 08:15 AM
  #36
CSP's Avatar
CSP
Hey banyan, What did you ultimately do?
Old May 24, 2017 | 08:21 AM
  #37
banyan's Avatar
banyan
Ended up selying it as is. Cylinder 1 was messed up due to broken spark plug electrode and did not have time to work on it
Old May 24, 2017 | 10:28 AM
  #38
50pascals's Avatar
50pascals
Originally Posted by Dennis Bratland
I used compressed air to keep valves from falling into a cylinder one time, and it worked, but it was scary. So many things could go wrong. Later I tried the feeding rope into the spark plug hole and pushing it up with the piston, and I felt much better while I was working. This wasn't on a Mini.
Just thought I'd throw that out there.
This is the preferred way to do it, and is pretty much foolproof. I have done much engine work using this technique. The compressed air way is OK, but too much can go wrong.
One way to improve this is to use natural bailing twine, or jute or sisal string. This way any little fibers that are left will burn up and turn to ash, not potentially get melted onto a ring or cylinder wall.
