How much walnut shell?
Old Sep 25, 2016 | 09:46 AM
big_iz's Avatar
big_iz
For those who have done their own intake valve cleaning, how much walnut shell media did you use? Is the 25# pack that comes with the kits enough or should I get more?
My valves at 59k are as bad as the ones I can find online -- surprised that some of the cylinders even run. Did some mechanical cleaning with a rifle bore brush, followed by some Seafoam, but I know they still need a complete cleaning to get it back in the right condition. I'm up for buying one of the $250 kits that have the blasting set plus the intake adapter, but would like to make sure I have enough media without having to stop mid-cleaning and get more media.
Thanks, Iz
Old Sep 25, 2016 | 11:21 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Seem to recall reading that people were using a 25lb bag with leftovers.
Here is a great how to on a BMW. https://docs.google.com/file/d/0B3Ta.../preview?pli=1
Old Sep 25, 2016 | 05:06 PM
big_iz's Avatar
big_iz
thank you!
Old Sep 26, 2016 | 10:00 PM
AutoCoarsen's Avatar
AutoCoarsen
I bought the 25lb box from Harbor Freight and I doubt I used even half of it. And that included a lot of waste while I figured out a good technique.
Old Sep 27, 2016 | 04:09 AM
big_iz's Avatar
big_iz
Did you build your own blaster (modify a HF gun with an extended tip) or buy the kit?
Old Sep 27, 2016 | 05:32 AM
MiniToBe's Avatar
MiniToBe
I personally do not recommend it for the reasons below. If you are sure to do it, CLEAN CLEAN CLEAN the chamber when you finish. good luck
Old Sep 27, 2016 | 05:46 AM
big_iz's Avatar
big_iz
You don't recommend the blasting or, which part? If you blast, make sure you clean the chambers completely?
I was going to try putting a compression tester fitting into the sparkplug hole and push air back through the cylinder after blasting and cleaning. If I rotate the engine backwards, I can get the intake valve open and let it push anything from the cylinder back out the intake.
Old Sep 27, 2016 | 06:13 AM
MiniToBe's Avatar
MiniToBe
the part that while you are blasting and collecting the shells on the other end. these particles are now covered with carbon and sticky too. perhaps you can add some sort of liquid cleaner with the shells so they dont stick anywhere. also good point to being the piston to TDC.
Old Sep 27, 2016 | 10:46 PM
AutoCoarsen
Made my own with the Harbor Freight blaster.
https://www.northamericanmotoring.co...ing-parts.html
Old Sep 28, 2016 | 05:04 AM
big_iz's Avatar
big_iz
Beautiful, thank you!
Old Sep 30, 2016 | 09:24 PM
big_iz's Avatar
big_iz
AutoCoarsen, thanks again -- made my rig up just as you described. Ended up not using the vacuum adapter 100% of the time as I just couldn't get the angles right and my valves were horrid caked.
Incredible how much more acceleration the car has now.
PhoR53
Jun 29, 2020 11:41 AM
cflowrider
Nov 19, 2016 12:37 PM
Vassil2013
Aug 31, 2016 01:34 PM
BackcountrySkier13_inAZ
Aug 29, 2016 11:03 AM
