What can cause boost fluttering on a 2006 MCS?
Old Aug 4, 2016 | 06:27 AM
  #26
nkfry's Avatar
nkfry
Originally Posted by Manny_cooper
I'll give it a try when it gets here. I like the readily available boost, it'll be good for autoX.
BTW I'm having to replace the hole plastic inlet tube. The part that connects to the BPV is cracked in one of the plastic welds, veeery veeeery small crack. The guy who did my clutch must have messed it up somehow. Not going to epoxy it.
WHY IN THE WORLD did BMW decide to design that part like that, it's so freaking fragile. They could've done a solid piece from a mold? SMH!
Might as well throw it in. I was adamant about it because I though that the newer BPV already had a somewhat stiffer spring, compared to earlier models.
We've been seeing more and more of those black intake ducts cracking, they are a bit fickle.
We have them in stock if you need one, make sure to keep the red clips out of yours though, they're worth their weight in gold!!
The latest revision of the MINI BPV is a bit more refined over the early valves, but yes they do still fail and many still get the yo-yo effect after awhile.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Aug 4, 2016 | 02:37 PM
  #27
Mini Mania's Avatar
R53
Here's my little one.
Can't wait to get it back on track.
That's my little one!
That red is sharp! Let us know how the track goes.
Old Aug 29, 2016 | 11:23 AM
  #28
Manny_cooper's Avatar
Manny_cooper
The DT BPV fixed my problems...or maybe something else did. FOr now I'll asume it was the BPV. But the car does not flutter anymore. Thanks DT.
My car is heavily modified, so I don't know if it does affect the how the OEM BPV works. Maybe the OEM BPV does not do good with the air volume coming through when more mods are added.
I vouch for the DT BPV, very good product.
Old Aug 29, 2016 | 12:22 PM
  #29
sevin's Avatar
sevin
Still falls on personal preference. If you don't have fluttering problems, sticking to OEM will save you money in the long run on gas.
Old Aug 30, 2016 | 04:44 PM
  #30
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Guys,
As the title states. I'm having a boost flutter problem under partial throttle towards 5-10 psi. It only happens in partial throttle. I get 16 psi at WOT.
Did a smoke test and it didnt show any leaks. I replaced the BPV and the throttle body.
Need help...thanks.
Lets start with the simple stuff.
1-What sort of Boost gauge are you running, brand ect
2- Did it come as a kit.
3- Did the kit come with the proper T-fitting meant for a boost gauge or did you just tap into a line off the Intercooler horn.
Old Aug 31, 2016 | 06:37 AM
  #31
sevin's Avatar
sevin
He said 2 posts above you that he fixed his problem with a DT BPV.
Old Aug 31, 2016 | 06:46 AM
  #32
-=gRaY rAvEn=-
Moderator
10-4!
Guessing then he had yo-yo effect and not boost fluctuation...
Old Aug 31, 2016 | 01:11 PM
  #33
Manny_cooper
I take it back. I have no fluttering now, but the car certainly does not feel like it should. It is hesitating instead of the flutter.
Will put back the OEM BPV until I solve the issue.
My start ups in the morning seem to be getting harsher, as in it starts up, idles, hesitates, idles back again, hesitates and idles correctly after warmed up.
This is about to get on my nerves already.
Old Aug 31, 2016 | 01:22 PM
  #34
Manny_cooper
Raven,
1. It is an auto meter
2. It was pre installed before I got the car. It looks like it was part of a kit.
3. The boost gauge is tapped with a T along with the FPR line.
Old Aug 31, 2016 | 02:33 PM
  #35
ZippyNH's Avatar
ZippyNH
Raven,
I suggest you check the vac lines...both to the bypass valve and the fuel pressure regulator...
Might be nothing...but the line to the fpr is tiny...so the split and extra volume of the hose to use it guage might be giving you a bit of a lag as it adjusts...just a WAG...
Switching the bypass valve might take a couple hundred miles for the car to adjust to the changes to WHEN the boost is seen....the ecu has always had issues with this timing...that's why there is the yo-yo that some folks see...
Like I said, check the vac lines....then let it run a bit, let the ecu adapt to the change you made.
Old Sep 2, 2016 | 08:49 AM
  #36
Manny_cooper
Zippy,
Thanks!
I checked all of those things. I had replaced all the vacuum lines with new ones.
The car had been adjusting for over 1k miles when I noticed the fluttering.
My question is:
If I pressurize the system over 5psi, why does the green gasket of the supercharger inlet tube leak? Am I no putting it in all the way?
"Theory":
I know the air is going in one way and certain that there is no pressurization before the supercharger intake side. I'm thinking that doing a pressure test by the throttle body is kinda pointless. (And yes, I'm plugging the PVC valve hose).
IDK, I'd like opinions.
R,
Manny
Old Sep 25, 2016 | 08:01 AM
  #37
Manny_cooper
Some pending codes I retrieved.
They make no sense at all. But, maybe it does to somebody.
VYPUR
Jul 8, 2016 12:07 PM
wetotter
11
May 28, 2016 07:57 PM
furnitureman9
How to
May 23, 2016 04:54 PM
wearlaz
May 7, 2016 11:05 AM
