Misfire cylinder 1
Old Jun 10, 2016 | 02:14 PM
mjcari's Avatar
mjcari
Misfire cylinder 1
Hi guys,
I bought this '06 r53 with 97k in it. Drove home from New York 2 weeks ago. Did inspection 2. Drove for a week. Today, misfire cylinder 1 code $13. Did compression test, 95 psi on cylinder 1. Must be a valve. What are my options? New head? Valve job? I have a leak down tester coming tomorrow. Opinions? Is this common?
Mike
Old Jun 11, 2016 | 08:14 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Burnt Exhaust valves can be problem if proper maintenance is not followed. And with 2nd gen MINI that have direct injection carbon build up can cause this.
For the 1st Gen MINI like ours however, one can of Seafoam into a full tank of fuel every other oil change to remove deposits is a good preventative measure. It's 6 dollars from Walmart, and will clean the back of the valves off very nicely....or you can use the MINI fuel injection cleaner with Techron. Either one a good choice.
GL with the LD test !
Old Jun 12, 2016 | 07:03 AM
mjcari's Avatar
mjcari
So I did the leak down test. I put 90 psi to each cylinder (warm, at TDC) and got the following results. Cylinder 1 = 28 psi, Cylinder 2 = 28 psi, Cylinder 3 = 78 psi, Cylinder 4 = 76 psi. No noise in intake, or exhaust. When pressurizing cylinder 1, you can hear the air in cylinder 2 (from the spark plug hole) and when pressurizing cylinder 2, you can hear the air in cylinder 1. So it's a BAD HEAT GASKET between cylinder 1 and 2. Only symptoms are misfire, cylinder 1, and poor fuel economy. It feels fast.
AoxoMoxoA
12
Aug 15, 2020 07:37 AM
a4dude
May 3, 2016 11:12 AM
slash695
Apr 3, 2016 01:43 PM
The duff king
Mar 24, 2016 08:26 AM
RebeccaC
Mar 21, 2016 07:47 AM
