looks like the Solenoid valve need replacing!
Im gonna go backwards on this issue of mine. The diagnosis shows that the "Solenoid valve (SOLV)" is responsible for the issue im facing! Wont tell you just yet what that issue is, so i dont get you biased to tell me what you think. So the real question is... what symptoms should i have if the Solenoid valve (SOLV) is faulty?
Oil pressure solenoid valve?
Mine would illuminate the low oil light on long sweeping curves, off ramps, etc.
It will "leak", however it pushes oil up the wiring harness into the module if not taken care of, there is a service bulletin and just a harness fix iirc
I get the following error msgs... P000A-Powertrain and P0420-Powertrain, might they have to do with it?
sdiver
Tires, Wheels, & Brakes
15
Mar 30, 2018 01:54 PM
JPMM
May 24, 2016 07:38 AM
TC Mini
R55 :: Clubman Talk (2008+)
May 16, 2016 09:48 AM
