Door lock problem
Old May 26, 2016 | 09:52 AM
Javskies's Avatar
Javskies
Door lock problem
Hello! i have an 06 r53. i was having a problem where my passenger door would lock when i used the key but wouldnt unlock no matter what and wouldnt lock if i used the console toggle. i just replaced the actuator and it is still doing the same exact thing. could it be a problem with the bcm? i have another problem where when i turn my key, my headlights turn on and my gauges light up as if the headlight stalk was in the on position but it is actually in the off position. i assume this could be associated with a bad bcm as well?
i heard that a bad ground somewhere in the systemcould also cause this? thanks!
Old May 27, 2016 | 05:36 AM
Yes, the BCM seems to be going. When you have mutipe problems its usually the BCM got wet from a sunroof drain leak or just from water getting inside and soaking the floor. From like an unclosed window
You will need the R50/R53 unit. 61356982114
https://www.northamericanmotoring.co...working-2.html
mini merle
Apr 4, 2016 07:52 AM
cl_reatta
Apr 1, 2016 08:43 PM
imbrilliant
Apr 1, 2016 04:05 PM
Omatic
Mar 22, 2016 07:46 AM
ilpavlov
Mar 16, 2016 06:10 AM
