cabrio rear weather strip ---options
Old 12-20-2016, 01:29 PM
bugeye1031's Avatar
bugeye1031
bugeye1031 is offline
Moderator
thanks for sharing R53coop!
  #27
Old 12-28-2016, 01:57 PM
Omer Humayun's Avatar
Omer Humayun
Omer Humayun is offline
Hmm, might give this a try in the spring. Parts cost alone up here in Canada's capital is $660 (!)
  #28
Old 12-30-2016, 12:08 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Whine not Walnuts is offline
Originally Posted by r53coop
The finished product. Picked up some exterior flexible chrome trim at the auto parts store. Wipe the black vinyl off with some lacquer thinner and then installed the trim, about 1/2" wide.
I removed the chrome trim and put on black trim. The double sided tape that was on the chrome trim held quite good. I was able to remove what was left by rubbing my finger, working from the front to the back that results in the tape rolling up on itself. Without the rubber, dirt becomes somewhat trapped but for money invested in this method vs buying replacement parts, I will trade the time for the money saved.
  #29
Old 12-30-2016, 01:41 PM
bugeye1031's Avatar
bugeye1031
Moderator
That looks great! Can you share any part numbers or packaging so we can get the same exact stuff?
Thanks!
  #30
Old 12-30-2016, 05:18 PM
Whine not Walnuts
The first pictures with the chrome strips are Cowles # S37750 that is 1/2" wide. The second in black are the same trim that I painted black with a bumper type spray paint.
I continue to look for different trim. The Cowles T3402C and S33216 are black trims that on the Cowles site are said to be 5/8" and 1/2" respectively in width. When I pull these up on Amazon, they appear to be wider. Cowles T4002 is a black door edge trim that might work as well. I need to check out a Pepboys as they sell allot of Cowles products. These range from $10 to $20. It takes about 6'.
The T4002 appears to be a "L" shape and if around 5/8" to 3/4" wide could work. If the tape is on the bottom side of the long L portion, this trim would push up against the fabric top and look more like the original trim that rots out.
Nix the T4002, it is only 27" long, back to T3402C and S33216
  #31
Old 01-10-2017, 11:20 AM
bugeye1031's Avatar
bugeye1031
Moderator
thanks for the update....
  #32
Old 10-04-2020, 11:58 AM
hawtdogflvrwtr's Avatar
hawtdogflvrwtr
hawtdogflvrwtr is offline
Found it!
I know this is a resurrection and I apologize for that, but I wanted to post my experience search and finally finding the perfect replacement rubbers for my convertible. I tested about 30 different types and finally found an inexpensive one from Amazon that looks factory. I just pulled the molding off, took a razor to remove the original rubber, cleaned the pieces really well with soap and water and then bug and tar remover before just applying the rubber to the pieces. You can't tell its not factory. After a day or so in the sun, the points where it turns around the vehicle are less buckled and smooth.
This is what I got from Amazon.
Amazon Amazon
The following 2 users liked this post by hawtdogflvrwtr:
cosmoKenney (02-28-2022), ssoliman (10-05-2020)
  #33
Old 10-04-2020, 04:24 PM
GearheadS's Avatar
GearheadS
GearheadS is offline
Wow! That's great! I'm gonna do it on mine, thanks!
  #34
Old 01-18-2021, 05:40 PM
charlieaosp's Avatar
charlieaosp
charlieaosp is offline
https://www.amazon.com/dp/B0868N399Z..._QRHEFbKBVRW6Z
Thanks a lot for the tip! Just purchased and will see how it goes.
  #35
Old 01-18-2021, 05:58 PM
hawtdogflvrwtr
Mine still looks like new. super pleased with it. looks brand new.
  #36
Old 03-12-2021, 07:35 AM
hawtdogflvrwtr
Here's a couple new link because the current one doesn't contain the trim anymore:
https://www.amazon.com/Support-Window-Moulding-Weatherstrip-Vehicle/dp/B07BFT78N3/ref=sr_1_6?dchild=1&keywords=xusha+4m+13+ft+univer sal+z-shape+trim+car+door+rubber+seal&qid=1615563228&sr= 8-6
Amazon Amazon
https://www.amazon.com/Rubber-Protector-Guards-Weatherstrip-Window/dp/B07JB817R2/ref=sr_1_20?dchild=1&keywords=xusha+4m+13+ft+unive rsal+z-shape+trim+car+door+rubber+seal&qid=1615563598&sr= 8-20
If this link dies, search "xusha 4m 13 ft universal z-shape trim car door rubber seal" on amazon and another should appear.
  #37
Old 03-21-2021, 07:32 AM
GearheadS's Avatar
GearheadS
Thanks!
lsnover
07-21-2021 11:57 AM
KevinR
Suspension
30
11-25-2017 12:07 PM
Cxracer
11
02-27-2011 06:17 PM
Sin MINI
12-28-2007 01:34 PM
Suji
55
10-22-2006 06:47 AM
Quick Reply: cabrio rear weather strip ---options
