Chain Tensioner Length?
Old Mar 12, 2016 | 05:58 PM
dn09MCS's Avatar
dn09MCS
If my new chain tensioner length is 82mm(Long one), then what should the new dummy tensioner length be? I have tightened the dummy tight, but do not wish to trash my new guide rails. I thought the old dummy length was 68mm, but there is no way you can get the cam on with it that tight. Help.
Old Mar 13, 2016 | 12:32 PM
oldbrokenwind's Avatar
oldbrokenwind
Sounds to me like you're doing things out of sequence. The tensioner tool should be used AFTER the chain is installed and BEFORE the cam sprockets are tightened. Cam installation procedure is spelled out pretty good in the Bentley manual. Doing it wrong could be catastrophic! Either search this forum for threads explaining the process (risky), or get a Bentley manual (recommended).
Old Mar 14, 2016 | 07:25 AM
nkfry's Avatar
nkfry
Guides in and tight
Crank and cam bolts loosely assembled so that they still rotate
install tensioner tool, tighten to 6 in lbs
Torque intake cam to 15 ft lbs + 180*
Torque exhaust cam to 15 ft lbs + 90* if N14 or 15 ft lbs + 180* if N12/16/18
Torque crank bolt to 36 ft lbs + 100*
Remove tensioner tool
Install tensioner, torque to 45 ft lbs.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Mar 14, 2016 | 08:50 AM
+1 on the timing : DIY here : N14
https://www.northamericanmotoring.co...ce-please.html
Gabe3
Dec 6, 2016 07:28 AM
arth4
Aug 9, 2016 10:02 AM
eliseo1981
Mar 13, 2016 10:30 AM
CosmicBlue15
Mar 4, 2016 09:10 PM
PhoR53
Feb 19, 2016 12:24 PM
