Help with bleeding coolant
Old Oct 24, 2015 | 01:02 PM
BbyDenns's Avatar
BbyDenns
2003 mini cooper S. 95k miles.
This is my first time flushing the coolant system. I drained it, hooked everything back up, but now the system won't bleed. I tried putting coolant in the bleed screw hole, and the coolant flows into the reservoir, but won't flow out. What am I missing?
Additional note: I replaced the reservoir because it was cracked.
Old Oct 24, 2015 | 07:21 PM
Racingguy04's Avatar
Racingguy04
Are you turning on the motor to bleed it? I've done this a couple of times but never had this kind of problem. Is there any chance that the opening on the new reservoir is blocked?
Old Oct 24, 2015 | 07:39 PM
BbyDenns's Avatar
BbyDenns
I did turn on the engine, and the heater. The lower bleed screw by the thermostat housing would bleed with the engine off and drain the tank level, but nothing would come out with the engine on. And the top bleed screw, by the radiator, nothing would come out of it. I'm so puzzled. I did drive my car around some tonight with no overheating, I'll check it again tomorrow and try to bleed it again.
Old Oct 25, 2015 | 05:35 AM
pav5069's Avatar
pav5069
you need the car hot enough. Just leave it open and let the car run for alittle and keep an eye on it.
Old Oct 25, 2015 | 09:13 AM
Da_Ghost's Avatar
Da_Ghost
Each time I've done it on mine, I turn the engine on for a bit, shut if off and open the top bleeder and repeat it until coolant comes out. Done it 3 times so far from removing the rad and never had issues.
Old Oct 26, 2015 | 02:35 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Follow our DIY here, which should help you with the bleed process. Bleeding starts at about the 9th paragraph from the bottom.
888.280.7799 | 6am - 5pm PST
Old Nov 2, 2015 | 05:45 AM
BbyDenns's Avatar
BbyDenns
This is the guide I followed when changing it. I did finally get it bled, however.
I think there was an air bubble trapped in the system somewhere and driving it a short distance removed it. Thanks for the help!
Old Nov 5, 2015 | 08:01 AM
Most likely its was trapped air in the system, did you bleed it gain after the shirt drive ?
Great info here:
https://www.northamericanmotoring.co...nt-system.html
Old Nov 6, 2015 | 06:28 AM
BbyDenns's Avatar
BbyDenns
Yes. After the drive is when it finally bled properly and fully.
Old Nov 6, 2015 | 08:34 AM
PelicanParts.com
Vendor
Wonderful. Glad everything is A-OK. You're very welcome.
Old Nov 6, 2015 | 08:37 AM
That's great, let me know if you need anything else
Apr 7, 2020 06:49 PM
Sep 11, 2015 10:32 AM
Marktheman
Sep 6, 2015 06:15 PM
Sep 4, 2015 03:56 PM
Sep 4, 2015 11:43 AM
