p0304 missfire and unusual compression
Old Oct 11, 2015 | 12:51 AM
Leema's Avatar
Leema
So im having a cylinder 4 missfire.
Ive done all the obvious ignition component swaps.
Coil
Plugs
Leads.
With no results.
she fires up runs beautifully. Idles normally.
Give it a good rev. Starts missing. Shut it off let it sit for 10 secs it them idles great again after a restart of course.
Ive done a compression test today. All 4 pulled 145 to 160 psi. Which im happy with. I decided to fire it up on each cylinder with the. Comp tester on it. 1 2 and 3 all get 350 psi under a good rev and cylinder 4 idles at 170 psi. Give it a rev she drops to 50 psi and stays there untill re start when it goes back to 170 again.
Im thinking a sticking hydraulic lifter or valve. Has anyone experienced this before on one of these?
Old Oct 18, 2015 | 04:54 PM
BuffMyRadius's Avatar
BuffMyRadius
That sounds like a bad tappet to me for sure. How many miles are on the clock? Or I suppose it's kilometers for you down on the big island?
Old Oct 19, 2015 | 09:47 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
OBD gives these possible causes:
Faulty spark plug or wire
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector
Burned exhaust valve
Faulty catalytic converter(s)
Running out of fuel
Poor compression
Defective computer
888.280.7799 | 6am - 5pm PST
Alanberto
Oct 19, 2015 12:31 PM
Nikkielynn
Oct 12, 2015 07:33 PM
Blues Trucker
Oct 12, 2015 07:52 AM
bshane
Oct 10, 2015 09:35 PM
teinesina
R60/R61 Stock Problems/Issues
Oct 10, 2015 09:26 AM
