Help diagnose coolant leak
Old 09-19-2015, 12:51 PM
cjny's Avatar
cjny
cjny is offline
My 2010 MCS with 65k miles is losing coolant very slowly. There are no drips on the garage floor and the cooling system easily passes a pressure test. A quick review of this forum suggests the usual suspects are water pump and thermostat housing. Can anyone offer tips on telling where the fluid is going?
Old 09-20-2015, 09:50 AM
AZdsrt's Avatar
AZdsrt
AZdsrt is offline
Most likely thermostat housing. From the reading I've done, slow leak that collects on top of the transmission..
Old 09-21-2015, 01:11 PM
ECSTuning is online now
Received 1,967 Likes on 1,767 Posts
+1 Its all here. Been there and done all of this myself. We were the first to mention the pooling effect.
https://www.northamericanmotoring.co...8-no-heat.html
At first you can get a small hairline crack at the bottom of the thermostat that leak a couple drips on to the transmission, ( why u cant find it ) , then after a while it pools and then drips down the back.
Old 09-21-2015, 01:28 PM
PelicanParts.com's Avatar
PelicanParts.com
PelicanParts.com is online now
Vendor
+1. Yes, it is common to pool on top of the transmission. Check out the water pump as well and look around the system for any signs of seepage/leaking. I've seen a water pump as early as 50k. There is a good DIY here on NAM for the thermostat and the OP posts some info about mileage for when his thermostat and water pump went. Thermostat here if needed. Let us know what you find.
888.280.7799 | 6am - 5pm PST
shorenetworks
11-04-2019 06:18 PM
ryGuyMCS
10-06-2015 12:04 PM
jarymo
Hawaii MINI Motoring Club
09-30-2015 04:19 PM
debitsandcredits
09-21-2015 08:34 AM
mimaal
09-04-2015 09:09 AM
Quick Reply: Help diagnose coolant leak
