Brake fluid smell and steam
Old Jun 28, 2015 | 09:49 AM
Phreshprince's Avatar
Phreshprince
Posted twice already about my 06 s 6 speed clutch going out. The squealing and popping when pressing the clutch. I've had 2 mechanics look at it and confirm the throw out bearing was squealing and pressure plate popping. $900 to have a new clutch put in :/ but whenever the car is started towards the back right a little bit of steam shows and you and smell brake fluid really bad. Could the slave cylinder went out when the clutch died on me?
Old Jul 1, 2015 | 02:03 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
It is definitely possible. When you press on the clutch, pressurized brake fluid moves from the master cylinder through either a metal or rubber line to the slave cylinder mounted on the transmission. A spongy feel to the clutch pedal, grinding of gears when shifting, long pedal travel, and hydraulic leaks under the car are all signs that one or more components of the system have failed. Have you replaced the clutch yet? Can you see leaks anywhere? Replacing the slave cylinder is actually pretty simple. Here is a DIY that can help you with doing the replacement to save some money. Can buy the part here if needed.
You can also save a good chunk of change by doing it yourself on the clutch job. We have a good DIY tech article here for the clutch replacement and parts here. Definitely requires proper tools and a bit of your time though.
Let me know if you have any other questions or need any other help.
-Luccia
888.280.7799 | 6am - 5pm PST
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
HaveATank
Sep 4, 2015 08:04 AM
HaveATank
Aug 24, 2015 10:26 AM
Redhotz
R55 :: Clubman Talk (2008+)
Aug 14, 2015 05:29 AM
