2005 MCS engine hesitation, surging
Old Jun 17, 2015 | 11:29 AM
GearheadS's Avatar
GearheadS
Hey all. I'm writing about three separate but possibly related anomalies.
1) Engine occasionally hesitates when trying to accelerate out of a fairly hard corner, usually in 2nd gear I think. It doesn't die or miss (like a bad plug), it just doesn't respond to throttle. I've only noticed it two or maybe three times, always during spirited cornering. Power comes back after less than a second.
2) Engine has somewhat "surgey" power delivery all the time when accelerating. I'm not referring to the drive-by-wire throttle delay, but rather when getting into the throttle a little in the 3000-4500 rpm range, where the supercharger is getting on the boost pretty good, the acceleration is not smooth, but rather surges slightly, like I was moving the gas pedal up and down 1/2" or so, not in any kind of regular pattern.
3) Have random intermittent SES light with a P0171 code, indicating a lean condition. This light comes and goes very sporadically, and I haven't noticed any correlation to the other issues, but maybe...
The car has a 15% pulley and K&N drop in filter, otherwise stock. Any ideas? Thanks!
Old Jun 17, 2015 | 12:52 PM
GearheadS's Avatar
GearheadS
Bump...added info to the original post.
Old Jun 20, 2015 | 10:08 AM
BuffMyRadius's Avatar
BuffMyRadius
I would suspect a fueling issue. Possibly a fuel pump or maybe filter. There is a schrader valve on the end of the fuel rail that you can hook a pressure tester to, they are a common rental tool at part stores.
That should get you started, after that my second guess would be something electronic related to AFR.
Best of luck!
Old Jul 8, 2015 | 10:33 AM
GearheadS's Avatar
GearheadS
I haven't had a chance to check this out, thanks for the suggestion. I need to try it. Despite the supposed lean condition, I think the gas mileage has suffered since adding the 15% SC pulley, and we don't drive around with our foot in it all the time. That is a little disappointing as well.
Any other ideas?
Old Jul 8, 2015 | 12:26 PM
jamez's Avatar
jamez
My thoughts would be the Bypass Valve (spring) is in need of replacement.
1) Just to check - the DSC wasn't kicking in right? During hard cornering under power, the DSC cuts power. Do you have the LSD?
Old Jul 10, 2015 | 08:32 AM
GearheadS's Avatar
GearheadS
LSD = limited slip, right? I'm not sure, but I don't think it has one. It does have the DSC, and that's a good idea for problem #1. It's doing it's job of keeping the car stable. That's why you can turn it off if you want, so it doesn't cut power. Thanks!
Old Jul 20, 2015 | 06:10 PM
portedbuckle's Avatar
portedbuckle
I had pretty much the same exact issue on mine. Same code and all. I ended up disconnecting the TMAP sensor and starting the car to see if the problem would occur right off the bat. It did, and I replaced the sensor. Been going strong ever since. Hopefully this helps.
Old Jul 30, 2015 | 10:15 AM
GearheadS's Avatar
GearheadS
TMAP sensor...something else to check out. Thank you!
iggi
18
Feb 9, 2026 01:00 AM
mdutton11
14
Oct 26, 2015 01:47 PM
polotska
Aug 23, 2015 09:10 AM
FLYM1N1
Aug 16, 2015 01:15 PM
Red Raven
Aug 11, 2015 04:48 AM
