Clutch questions
Old Dec 22, 2014 | 04:39 AM
qolor's Avatar
qolor
Clutch questions
tl;dr does it have a valve in the clutch line to cause excessive slip (like some BMWs do), and if so, how does one remove it?
Hey guys, I own a 05 (produced 04) R53 with the 6 speed. I have been driving it for close to a year and have a question.
Obviously, our clutches are very different than some other types. Do our clutches have that stupid valve that BMW puts in line so we can't "pop" the clutch, or release it too quickly? Basically, if you power shift from first to second (which I do sometimes..) I can hear it noticeably slipping (or wheel spin, can't tell, mainly happens on cold days)
transmission was replaced at 65k (endbell housing cracked..???) and now it is at 95k. Unsure if the clutch was replaced at this time.
Thanks guys.
Old Dec 22, 2014 | 05:14 AM
mrbean's Avatar
mrbean
No, it does not have a clutch delay valve (CDV).
Old Dec 22, 2014 | 05:16 AM
qolor's Avatar
qolor
Alright, thanks. Time to start saving for a clutch replacement and take it easy until then, lol.
Old Dec 23, 2014 | 07:29 AM
nkfry's Avatar
nkfry
There is not anything that makes our clutches different from the rest, they all use a flywheel, pressure plate, friction disc, throw out bearing, and a slave cylinder to engage/disengage it. Biggest difference is going to be the dual mass flywheel the S cars had from the factory, but that is even becoming industry norm with all the manufacturers.
95K sounds a touch low for clutch life, but it depends soley on the driver, and conditions driving in. As long as you don't slip it constantly you'll still see months of driving without issue,
We sell a Valeo clutch single mass flywheel conversion kit that is priced right, and is a great setup.
Let us know if there is anything we can do to help,
Nick
Detroit Tuned
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Dec 26, 2014 | 12:08 AM
BigGunz's Avatar
BigGunz
I recently installed the Valeo SMF Conversion Kit on mine. Works great just a little rougher at idle than the stock DMF.
Sent from my Droid Mini using NAMotoring
Old Dec 26, 2014 | 02:54 AM
mini yellow-haa!'s Avatar
mini yellow-haa!
Wow you already did your clutch. Cool!
Old Dec 26, 2014 | 09:01 AM
BigGunz's Avatar
BigGunz
I had to. It was starting to slip really bad.
andrewjg1994
Jan 29, 2021 07:45 PM
eliseo1981
Jan 28, 2021 02:45 PM
Sep 17, 2015 09:27 AM
Camaro108
Aug 25, 2015 02:44 PM
DiGiPiMP
Aug 24, 2015 11:04 AM
