06 manual trans issue
Old Nov 30, 2014 | 09:14 AM
javelina1's Avatar
javelina1
Went out this morning to fire up my 06 MCS. I'm unable to put the car in any gear when it's on. When I shut the engine off, no issue with putting the tranny into all 6 gears and reverse.
I've checked, and there's plenty of Dot 4, (at the high mark).
The car has 78K miles on it. So still very young.
Cable adjustment, to get more clutch engagement?
TIA,
-Jav
Old Nov 30, 2014 | 09:19 AM
ZippyNH's Avatar
ZippyNH
Clutch is hydraulic.... So self adjusting.
I would pump the cluch a bunch...
Then look for leaks or drips...think the master/slave died...just a guess..
Old Nov 30, 2014 | 09:22 AM
javelina1's Avatar
javelina1
will do, (clutch pumping).
I'm also hunting around here, and seeing the slave cylinder cropping up.
Old Nov 30, 2014 | 09:33 AM
javelina1's Avatar
javelina1
pumped the sh** out of the clutch. 200+ times. Checked the Dot 4 level, full.
Still couldn't get the car to go into any gear, while turned on. Turned off, no issue.
Then I noticed a leak underneath her. (The car has been sitting for a few days). Ran my finger over it, and it feels like Dot 4 fluid.
So I'll check out the slave cylinder.
Old Nov 30, 2014 | 09:49 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
If your seeing a leak def check the slave cylinder as they are pretty common to fail.
Old Nov 30, 2014 | 10:20 AM
javelina1's Avatar
javelina1
Thanks Way, I'm checking it out. appreciate the insight.
Old Dec 1, 2014 | 10:16 AM
Vkng's Avatar
Vkng
This is video of my slave cylinder, to give you an idea of the distance it needs to move to function. If yours seems to move about this distance it likely is something internal.
09R56
Nov 16, 2022 10:49 AM
arf88
May 31, 2016 03:07 PM
theblackfalcon
Oct 11, 2015 09:49 AM
Norton70
R57 :: Cabrio Talk (2009+)
Aug 18, 2015 04:29 PM
speedbird_1
Aug 15, 2015 04:44 PM
