front end sounds loose when make slow turn (mainly to right)
Old Aug 12, 2014 | 11:51 AM
mona5255's Avatar
mona5255
What could it be some suggestions, when I make a slow right turn the loose or clunking noise in most noticeable. I have had strut mount replaced, motor mounts, even put new muffler strap and clips. Have new brakes, new tires (Nexen). Still that ever present clunk - 2 mechanics and still doing it. Could it be the CV axle boot, control arm, or the drive shaft itself?
Old Aug 13, 2014 | 09:29 AM
quikmni's Avatar
quikmni
Could be a torn top strut mount rubber bushing. Look at it from the engine compartment.
Could be that the top strut mount bolt is not threaded all the way down so the strut is moving around a little. Should be able to grab spring to try and move with jacked up a little.
Could be CV Joint, is the boot ripped/torn?
Could be the lower control arm bushings.
Old Aug 13, 2014 | 03:32 PM
mona5255's Avatar
mona5255
Thank you I will check it out.
Old Dec 14, 2014 | 02:35 PM
mona5255's Avatar
mona5255
turned out to be ball joints and end links she's got a strong front now
silence2-38554
Nov 12, 2015 09:39 AM
ASRman
Aug 13, 2015 09:33 AM
FatherG
11
Aug 7, 2015 07:49 PM
