Catalytic convert split!
Old Jul 15, 2014 | 09:37 PM
Breakmywallet's Avatar
Breakmywallet
Hey guys. Prepping to sell my mini here pretty soon and I was driving 65-70mph on the freeway and my car becomes suddenly very loud. Towed it home and realized that the exhaust section coming out of the first catalytic converter is detached. Im guessing the cat is clogged and heated up that part so much that it popped out. Has anyone cut out that section and put in a universal cat? seems like the cheapest option at this point and I don't have the time to install the entire cat/exhaust manifold. Any problems (in CA) with installing a universal cat? Thanks for your help in advance.
Old Jul 15, 2014 | 09:42 PM
HummerFanatics's Avatar
HummerFanatics
Mine did the same thing...... I pulled the exhaust, took it to a welder ..... $60 he welded the heat shield all the way around ( where the weld broke )
No more problem, nice and quite
Old Jul 16, 2014 | 12:04 AM
Breakmywallet
I feel like if it is getting that hot, the cat has to be clogged. Should I replace the cat or just reweld it?
Old Jul 16, 2014 | 03:59 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
If the cat were clogged, your car would've run as though it had COPD (cough, cough) and would've probably thrown a code. One way or the other, you'll have to pull the header. If possible, I'd try to have it repaired.
Old Jul 16, 2014 | 04:02 AM
xsmini's Avatar
xsmini
Not clogged, they do that stainless steal to normal steal = poor weld. Both mine have done it, pop it off, weld it up, easy fix.
Nik
Old Jul 16, 2014 | 05:35 AM
astroBlackMetallic_Mini's Avatar
i have a stock header if you wanted to buy it; if you dont go the repair route.
Old Jul 16, 2014 | 06:00 AM
Breakmywallet
Good to know. The header has to come off the car in order to weld it, correct?
Old Jul 16, 2014 | 02:27 PM
BRG's Avatar
BRG
My cat split apart and my mechanic welded in a steel collar ( made up of two "c" sections ) to join the cat back together. If it's not a clean split you may have difficulty.
This was done with the cat and header on the vehicle.
Five minutes, $60. Better than new !
Old Jul 16, 2014 | 07:12 PM
05r50's Avatar
05r50
You didn't say how many miles you have but I recall that the CAT has a longer mileage warranty for some reason. Call your dealer and ask first. It may be covered.
Old Jul 18, 2014 | 09:45 AM
Breakmywallet
got it fixed for $40. Thanks for all of the information, guys!
shorenetworks
Nov 4, 2019 06:18 PM
Sep 18, 2015 02:44 PM
Sep 14, 2015 12:48 PM
Sep 10, 2015 10:52 AM
Sep 4, 2015 12:20 PM
