P0301 Misfire
Old May 8, 2014 | 05:05 PM
richas's Avatar
richas
P0301 Misfire
Hi,
I have a 2005 R50 Cooper. A while back I replaced the O2 sensor after I got an error code, can't remember the number but it was "post cat mixture rich" or something. That fixed that problem.
Months later I get a P0301 Cylinder #1 misfire fault. The engine started running rough like it was on three cylinders.
I find a corroded terminal on the coil and so I replace the coil (MSD), wires, and plugs. Seemed okay for a while.
Then it came back. So I moved the #1 injector to #3. This did not help.
I put the old spark plugs back in, no joy.
I have gotten the fault and reset it MANY times.
The typical symptoms are:
The engine may be idling a bit rough, like a partial misfire.
It never occurs when I am on the gas or the highway and I commute 40 minutes each way everyday.
I will take my foot off the gas and the engine will stumble, the light will come on (blinking first), and the car will be running rough like it is running on three cylinders.
Here is an interesting bit, if I turn the car off and restart the problem goes away. Though the idle always seems a bit rougher than it should be.
Not sure what else to do besides try an ECM. ($$$$)
Rich
Old May 13, 2014 | 10:24 AM
richas's Avatar
richas
Ordered a Fuel pressure gauge. The next time this happens I will pull over and measure........
Rich
Old Jan 28, 2016 | 07:56 PM
todd.ross's Avatar
todd.ross
Did you find anything? I just started receiving the same error. Turns out it is the PVC/Valve cover allowing oil to saturate the #1 spark plug.
Old Jan 29, 2016 | 03:40 PM
richas's Avatar
richas
Lost compression in all cylinders, shop guessed it was the rings. In any case I had to replace the motor with a used one.
$5k
And now there is a bad clutch engagement shimmy.
Looking at Subarus....
Rich
Fordgt4
Oct 10, 2015 10:42 AM
randeez
Oct 5, 2015 09:23 AM
dutchhome
Sep 30, 2015 07:17 AM
silence2-38554
Sep 28, 2015 12:19 PM
ShadyCoop
Sep 20, 2015 08:57 AM
