Need some advice regarding gas tank issue
Going to need a better manual, anyone have any thoughts on what they did? And more importantly, let us know if it worked!
Will do... now it's just wait and burn up gas so I can refill the tank to see how it goes.
UPDATE:
Okay, so they replaced the entire gas tank last time around... just filled up again, BAM, same issue.
So far they have replaced the charcoal filter and the gas tank itself. No fix yet. Mini back at dealership for the 3rd time now for exact same issue.
Millerb7,
Sorry to bump up such an old thread but was your issue ever resolved? I have a 2013 Countryman S with a DMTL fault code and it was contaminated with fuel. The charcoal canister was even filled with fuel. I'm going to recommend the customer to replace the DMTL pump and charcoal canister but need to find out why excessive fuel is entering his charcoal canister. The car only has 20,957 miles and the customer says that he never tops off his fuel tank.
- Jon
- Jon
I'd also like to know if this was ever resolved. There is a service bulletin for gas tank vent valve failure (presumably that is the "ball") for 2014 models. There's also an extended warranty for EVAP solenoid/valve under the hood, but in my research this should throw a CEL.
My vehicle has started doing the same, won't fill up and even when filling with a gas can, fuel refluxes out after 1/10th of a gallon. I disconnected the EVAP solenoid (front passenger side under hood) and it still wouldn't take gas. Then I disconnected the charcoal canister (near exhaust on rear drivers side under vehicle) and there were no charcoal pellets in the line. I blew air into the gas tank via the tank vent line, which perhaps temporarily unstuck the tank ball valve and allowed me to fuel up...for now. Unfortunately mine is 2015 and not included in the service bulletin so not eligible for free fuel tank replacement.
The line is under all the silly plastic shielding in the driver's (left) rear of the vehicle. The gas tank is behind the passenger rear wheel well. You don't need to take the plastic shielding off of it, but you will see a rubber hose going from that direction to a black plastic canister/box (charcoal canister). That cannister then has a hose running toward the front of the vehicle to the EVAP (and I think another hose comes out, not sure what it does). I took the hose from the gas tank off the charcoal canister and blew into it with the gas cap open (and a screwdriver in the hinge underneath the gas cap to keep it open). I'm out of town, can try to post some pics when I get back. It is still working, knock on wood.
Mine started malfunctioning again yesterday, 3 different gas station attempts and maybe a grand total of 1 gallon in (and some of that was spilled down the side of the car). I guess I'm going to have to do this procedure again. How long did yours last? If it happens another time, I might just have to she'll out for a new fuel tank assembly.
jadenmart
Aug 22, 2017 08:28 AM
san diego motoring
Jul 3, 2014 01:19 PM
adgeman
R55 :: Clubman Talk (2008+)
May 10, 2010 10:09 AM
MalteseFalcn
May 27, 2008 04:00 PM
