Can't get my seat heater to stay on!! :(
Old Jan 14, 2014 | 06:50 PM
thevastdifference's Avatar
thevastdifference
My drivers side seat heater refuses to stay on. Sometimes when it's 10F outside though, it will stay on for around 5-10 min. I checked the wiring underneath the seat, looks fine. Connections on the switch are fine. Added dielectric grease to the pins too. Nothing works! Passenger side has no problems at all. What else and where else can I check??
Heeeelllppp it's cold in Chicago!
Old Jan 15, 2014 | 12:26 AM
ryanschram's Avatar
ryanschram
same here except on my r55!
Old Jan 16, 2014 | 06:34 AM
Kidwell754's Avatar
Kidwell754
Same. R53. I thought I smelled burning plastic a couple days ago on mine. When im tearing it apart this weekend to do some other work ill see what I can find under my seat.
Old Jan 16, 2014 | 06:42 AM
ZippyNH's Avatar
ZippyNH
Usually if the heater turns off, the matt under the seat cover has failed....the circuits wear from bending...overheat...then the resistance change causes it to shutoff...a few folks have gotten burnmarks on the seat...of even pants in a tiny spot...where the circirt has failed...
Real solution is to take the seat cover off...and replace the matt.
Old Jan 16, 2014 | 12:55 PM
Yes,
I have seen a few burn the seat, most were from the Gen 1 MINI. I think its dues to sharp pinpoint pressure to the heating element and over time they can break. Gen 1 I believe the pad and the element are one.
https://www.northamericanmotoring.co...eat-cover.html
https://www.northamericanmotoring.co...seat-burn.html
Check the connections under the seat and rear upper of the seat where both wire harness make it to the main pad.
Gen 1 Part of the seat pads.
Gen 2 , separate elements
gsredmini
Oct 20, 2015 07:43 AM
minimofo
Sep 30, 2015 12:26 AM
please_remain_calm
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:33 PM
SeattleF56
Sep 3, 2015 03:01 PM
