R53 A/C compressor bearing noise. Need help.
Old Dec 26, 2013 | 11:53 AM
temka101's Avatar
temka101
Hi, I got a 2003 MINI cooper s and the bearing on the AC compressor got some water inside it and it's making alot of noise(both On or OFF noise doesn't change). To make sure I took the belt of and spun the pulley by hand and it was rattling. Basically just sounds like a dry bearing. I was wondering if replacing the clutch coil would fix this or do I have to get a whole new unit?
Thanks in advance
Old Dec 26, 2013 | 01:07 PM
gknorr's Avatar
gknorr
There is a bearing in that pulley. If it's rattling when you spin by hand (it should spin freely), I'd say replace the clutch coil.
Old Dec 26, 2013 | 01:11 PM
temka101's Avatar
temka101
Thanks . Yeah it spins freely by hand just makes noise.
Old Dec 26, 2013 | 01:33 PM
gknorr's Avatar
gknorr
Just make sure you get the part that includes the pulley. You can get the coil alone on eBay, but it doesn't include the bearing you need.
I used Delphi part #01650060.
Here's my write-up on it:
https://www.northamericanmotoring.co...utch-coil.html
Old Dec 26, 2013 | 02:14 PM
temka101's Avatar
temka101
Unfortunately, I can't seem to find it anywhere online. Looks like I have to get a whole new unit. :(
Old Dec 26, 2013 | 05:05 PM
gknorr's Avatar
gknorr
Wish I still had my old one which still had a good bearing on it - I'd ship it to you.
Looked at some of my old pictures from when I did the repair - the part number is actually 0165006/0, which turns back a number of results in the UK. Looks like amazon.co.uk will ship to the US. Here's the link:
Delphi 0165006/0 Air Conditioning Compressor: Amazon.co.uk: Car & Motorbike Delphi 0165006/0 Air Conditioning Compressor: Amazon.co.uk: Car & Motorbike
More than I paid for the part, but still way cheaper than a new compressor, evacuating and refilling the system, etc.
You could also find a used compressor, or even non-functioning one from a junkyard and use the piece with the bearing. Or, see if you could remove the bad bearing and press a new one in. Maybe more work than it's worth, but at least an option. The bearing is in the middle of this piece:
Finhead
105
Aug 14, 2023 07:51 AM
andrewjg1994
Jan 29, 2021 07:45 PM
damncajun
Aug 17, 2015 08:25 PM
PrimePower
Aug 16, 2015 06:29 PM
Fizzyx
Aug 14, 2015 08:24 PM
