p1338 with half engine
Old Dec 9, 2013 | 08:48 PM
pappasmurf's Avatar
pappasmurf
I'm in need of assistance please. I've had my mini 09 clubman s for a little over a year and about 2 months ago I started getting the half engine symbol after hard acceleration and quickly letting off the gas at about 40 mph. Then I lose power and the light comes on. It finally gave a code after I had to replace the battery over the weekend. The code is p1338 which is the camshaft sensor. Well I just replaced the sensor and it didn't help... does anyone else know what would cause just that one code?
Old Dec 10, 2013 | 10:14 AM
Nitro Jake's Avatar
Nitro Jake
engine timing off or problem with vanos would cause this.
Old Dec 10, 2013 | 12:04 PM
pappasmurf's Avatar
pappasmurf
That's what I was afraid of. This morning it did start throwing another code p1497. I will look up more on the vanos. Thanks for the reply!
Old Feb 10, 2014 | 06:46 PM
monkey661's Avatar
monkey661
Did you get anywhere with this?
Old Feb 10, 2014 | 07:02 PM
pappasmurf's Avatar
pappasmurf
I have read other places that it is probably the turbo diverter valve. But i haven't had the opportunity to get another one yet. Google "mini cooper diverter valve diagnosis" that is where I found some info. It is a rubber type diaphragm that can get a tear. symptoms half engine after letting off the gas at around 3700 rpm. does that sound like your issue?
Old Feb 10, 2014 | 07:13 PM
monkey661's Avatar
monkey661
I'll check that out, thanks!
Getrieben
Sep 12, 2024 07:03 AM
rob&JCW
Feb 13, 2023 07:03 PM
blackie
Jan 18, 2017 09:56 PM
FLYM1N1
Mar 7, 2016 05:41 PM
silence2-38554
Nov 12, 2015 09:39 AM
