PS Line Leak
Old Dec 5, 2013 | 12:20 PM
05inim's Avatar
05inim
PS Line Leak
I was too quick to assesed that my MCS was leaking coolant!!! it is one of those things when you are new to a car! (trying to rationalize my stupid mistake ), I did not have a Service manual, so I did not check location of TStat for leakage, I saw a greenish puddle under the car and assumed it was coolant.... (Tstat and housing replaced couple of weeks ago, now I know how to thanks to NAM and you all) well leak was not coolant, I found out this morning, it is power steering fluid!!! . Maybe a $0.50 cent band clamp could have fixed my problem, it looks like the leak is coming from upper hose attached to P.S. reservoir. "Advice" get a service manual and a really good flash light
Now if some one can direct me to the "how to thread" for power steering leaks will be greatly appreciate it
Old Dec 6, 2013 | 12:02 PM
<05MINI>'s Avatar
<05MINI>
well at least you have located the problem. good luck
Old Dec 6, 2013 | 12:49 PM
ashchuckton's Avatar
ashchuckton
Make sure to use the correct fluid. Using anything else can be a costly mistake.
http://www.ebay.com/bhp/bmw-power-steering-fluid
Old Dec 6, 2013 | 04:47 PM
minsanity's Avatar
minsanity
Change all PS hose clamps to screw type. Use only Pentosin CHF11S fluid.
Old Dec 6, 2013 | 05:53 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
"Sometimes" as a temporary fix, just cutting off the OEM clamps and installing new hose clamps will work, but not for long. The one from reservoir to pump is in a very hot area of the engine bay, so it loses it's resiliency becoming hard preventing a tight seal no matter how tight you make the new clamps. But of the three PS lines, the cheapest and easiest one to replace.... Part no. 32416754498 - #1 in diagram below.
shorenetworks
Nov 4, 2019 06:18 PM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:34 PM
mimaal
Sep 4, 2015 09:09 AM
Sep 2, 2015 09:05 AM
