R53 Mini S Slave cylinder
I didn't run the car after putting the power steering fluid in the clutch line and I didn't press the brakes at any point. I took the master and the slave off and flushed both the line and both cylinders, and while some of the fluid got into the brake reservoir, I used a turkey baster and sucked out all contaminated fluid. so the brake line should be fine. but I can't seem to get fluid to fill the clutch line using the method shown in the video after putting everything back together. is the master finicky or did I screw it up and need to be replaced?
OK--not the only one that hates this clutch system
Best method
1-prep the new slave cylinder with flat bar and 2 bolts as shown in video--completely compress the new slave
2-remove old slave from transmission leaving feed line attached.
3-swap slaves
4-leave slave hanging and attach the pressure bleed tool and pump it up
5-open bleeder with slave hanging--bleeder above the feed line. Close the bleed screw
6-release new slave most of the way -- as you release the screws the slave will fill with pressurized fluid and no air. Open bleed screw again with the slave hanging down (air will rise). Close it again.
7-install slave (best to release pressure from bleed tool)--be sure to keep it partially compressed (by hand) as you install it. The piston can be pushed completely out of the cylinder and the rubber seal can be damaged when you try to push it back into the cylinder.
At this point it should be fully functional with no air but you may want to reattach the bleed tool and give it a quick bleed to be sure.
This whole thing is a PITA
Best method
3-swap slaves
Best method
3-swap slaves
Best method
3-swap slaves
Having a major issue though. Ordered both slave & master from Pelican. Replaced both. Slave cylinder didn't come with the rubber seal for the end of the hydraulic line, so transferred my old one over. Used a hand pump to bleed the system. First time I pushed the clutch pedal down by hand to test firmness, I had brakefluid bleeding out from the union on the slave cylinder. Retaining clips were in place fine.
Issue that I replaced both for was clutch pedal going to the floor & staying there while driving. Didn't notice fluid all over the splash plate when I removed it to access the slave cylinder. Didn't notice any puddles in the driveway either.
Can't seem to find a listing for the bloody rubber seal anywhere, and contacting Pelican has gotten me nowhere.
Any suggestions?
Hey at least you noticed the rubber seal--first time I tried it was still in the old slave--nice mess.
Looks like it only come with a new pipe part#21526759854--typical BMW. Maybe Pelican can help or maybe at a wrecker for a used pipe, seems like a pita to me. Same a the red vacuum attachment at the supercharger--need to by the whole super charger or intake pipe to get a replacement unless you look really hard for one.
BTW if you drill a large hole in your plate (center between the bolts) with a step drill, it will hold the piston much better-- no slipping--forgot to mention that. Just keep making it larger with the step drill until the ball end of the piston sits nicely.
Couldn't find the hydraulic lines on Pelican. Looks like mini mania and a few other sites may have them, or I can take an hour ride on the bike up to the stealership if I take some time off work and try my luck there...
And here I thought when I ripped the nose clip off and did the supercharger oil change, that would be the longest time I had the S up on stands. You would almost think Lucas found a way to engineer this clutch system from the bowels of hell and get them on the drawing boards for production....
Last edited by Twistyd; Jul 9, 2014 at 05:23 PM. Reason: I can English real good sometimes....
Put you order in and we will do our best to get this faster.
http://www.ecstuning.com/Search/SiteSearch/21526759854/
"That being said, you just moved to the top of the list for my future parts."
Thanks Twistyd
Thanks Twistyd
Compressing the slave cylinder
For what it's worth had filled my new slave with fluid, bolted it back in place and compressed it completely using a plastic zip tie and a washer that I had flatten two sides so the zip wouldn't slip off. Worked perfect! The washer fit over the domed tip and is what depressed the slave cylinder. I'll try to post a photo.
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
