Need help, Electrical system problem
Old Jul 19, 2013 | 08:11 AM
Tom Troy's Avatar
Tom Troy
When I tried to start my 05 Mini Cooper S the systems went crazy. All gauges, hvac motors making noises and the headlights flashing. Nothing from the starter.
I disconnected batt ground, activated flashers to empty capacitors, waited to re connect and no change.
Anyone experience this?
Thanks for any help
Tom
Old Jul 19, 2013 | 04:21 PM
baznight's Avatar
baznight
Sounds like a bad battery. You've more than likely have a bad cell. Get it tested. Also check your battery cables and the main ground at the passengerside motor mount.
Old Jul 19, 2013 | 04:50 PM
Tom Troy's Avatar
Tom Troy
You are correct. Fairly new battery but started my troubleshooting there and 9.6 volts. Charged battery, and car started. Checked ignition on v - 12.4. Started engine and v is 12.3. Bad word but I assume the alternator is bad.
Seems like changing the alternator is a major repair!
Old Jul 19, 2013 | 06:42 PM
baznight's Avatar
baznight
Its actually not that bad. You will need a belt tool to remove the belt and you will need to put the vehicle in service position. There are several threads on how to do that. All in all its not that difficult.
iggi
18
Feb 9, 2026 01:00 AM
David.R53
Sep 1, 2015 06:51 PM
Aug 12, 2015 01:24 PM
Terry Gallentine
Aug 11, 2015 03:31 PM
