Classic LCA bushing replacement
I guess when you are over 90k these things are expected. Has anyone had a shop replace their lower control arm bushing/joint? How much did it cost you?
I cost some wiggle going in in my passenger side front wheel and the brake moves along with it so I ca only imagine its a bushing or some loose suspensions.
So they can reuse the joint and just put a new pushing in?
So they can reuse the joint and just put a new pushing in? It seemed like the entire lie Ed needs to be replaced.
Book time, according to KSD, is 2.8 (warranty) usually multiplied by 1.5 or 1.6 flat rate hours. multiply that by the shop rate- $100-$140/hr. You can buy the whole housing with a new crappy bushing, you can buy a new crappy bushing without the housing, or you can buy polyurethane bushings that totally kick ***.
silence2-38554
Nov 12, 2015 09:39 AM
minipopkart
Aug 13, 2015 05:22 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
