How to check for exhaust leak?
Old Apr 21, 2004 | 03:38 PM
dcsmd007's Avatar
dcsmd007
Coordinator :: PDX MINI
After installing the Milltek header and exhaust, I want to make sure that there's no leak in the exhaust system. Is there a way to check for exhaust leak?
_________________
Old Apr 21, 2004 | 04:21 PM
early_apex
Here are a couple things to try.
Old Apr 21, 2004 | 04:23 PM
Eric_Rowland's Avatar
Eric_Rowland
You mean at the head, or at the cat? Both?
Exhaust leaks are usually accompanied by a sound.
Alternatively, they tend to leave carbon (black) stains whereever it's leaking.
Easiest check is to start up the car cold and move your hand around all the mating surfaces (easier at the cat than the head!!)
After it's got a few hours on it, just do a visual and you should be fine. Most exhaust leaks are caused by crimped gaskets (unless its a sleeve fit), and in my experience they're quickly found.
Old Apr 21, 2004 | 05:07 PM
kenchan's Avatar
kenchan
I tend to re-torque everything after a test drive while the exhaust is somewhat hot
just to be sure.
danielbrookes_9
Oct 3, 2015 12:51 PM
Etrain
11
Aug 20, 2015 10:22 AM
elightbo
Aug 17, 2015 01:50 PM
ASRman
Aug 13, 2015 09:33 AM
massmini03
Aug 12, 2015 11:19 AM
