HELP!!! Control arm stuck to ball joint!
Old Aug 20, 2018 | 05:39 PM
  #26
Tgriffithjr's Avatar
Tgriffithjr
Good job! Way to hang in there!
Old Aug 25, 2018 | 04:48 PM
  #27
tommydoo66's Avatar
tommydoo66
generally speaking, is it easier to remove the inner ball joint connection first than the outer since you have the pressure of the spring and weight of the wheel carrier on the outer?
I am doing my LCA bushings next week using the MINI press tool from ebay and putting in Power flex.
Old Sep 26, 2018 | 06:13 PM
  #28
dzb's Avatar
dzb
There are a ton of threads and youtube videos on separating the inner and outer ball joints. I've read/watched most of them, to get ideas on how to pop the ball joints. Most folks recommend using a large pickle fork on the inners. Uhh... pass... I don't want to tear the boots, as I'm not planning on replacing the joints (just need the LCAs out to replace the bushings w/ Powerflex).
I haven't seen any mention of what finally worked for me: thread a 3 ft steel stake ($5 at Lowes) from above, and hit it hard with an 8lb maul ($35 at Lowes).
First, I dulled the pointy end a bit, by hitting it with the maul.
For the outers, I turned the wheel and threaded the stake next to the brake calipers, with the stake's pointy end resting in the LCA's indentation, right next to the ball joint pin. The stake extended up and a little away from the car... 4-5 hits and the outers separated.
The passenger inner was similar, except I used the stake's flat part against the LCA, right next to the inner ball joint. The stake thread up next to the oil filter, into the engine compartment.... 6-7 hits on the stake pointy end and the joint separated. (The driver inner actually separated itself when I popped the driver outer... go figure...)
The whole thing was a PITA, because I tried a dozen different methods before figuring out the stake thing. Wish I started with that ;-)
Old Sep 26, 2018 | 07:25 PM
  #29
Tgriffithjr
Uhhh....pass. If I’m separating ball joints with any method I’m replacing them so the boots don’t matter. Besides, new boots are cheap.
Old Dec 18, 2021 | 10:03 PM
  #30
Roxious55's Avatar
Roxious55
I
Originally Posted by Andrew Riley
It's all done! Thank God that mess is over with.
Tips above. ^^^
Congrats man I feel your pain I'm still having the same problem I cut the ball joint off over top of the control arm and went ahead and pressed the new ball joints in because I had to get the tool back so I could get my money back now I'm stuck with the bottom of the ball joint in the control arm I've tried everything cannot get it out
Old Dec 19, 2021 | 08:07 AM
  #31
ssoliman's Avatar
ssoliman
With the subframe out I beat on the top (shaft) of the ball joint. It eventually popped free but I had to saw off the tip of the ball joint shaft. It was mushroomed.
Maybe keep the bolt on the shaft to keep it from mushrooming?
plan on new joint and hardware…
Old Oct 30, 2022 | 10:48 PM
  #32
stiksandstones's Avatar
stiksandstones
DAYS, ive been trying to get that inner control arm ball joint out of 2013 countryman, DAYS!
Any new tips for us stuck pin people?
#nightmare.
  #33
stiksandstones
You beat the TOP ball? wouldnt that push it into the tapered shaft even more??
wajulia
Dec 9, 2018 01:05 PM
tracktoy990
Suspension
May 13, 2009 01:40 PM
JAB 67
Jan 23, 2009 10:49 AM
meb
Suspension
Apr 11, 2007 02:23 PM
