P0136 fault code
Old Feb 26, 2013 | 06:13 PM
northbarts's Avatar
northbarts
P0136 fault code
My 2002 MC spit out a P0136 fault code which pertains to the O2 sensor (bank 1 sensor 2). Is that the post cat O2 sensor and should I assume this to be the cause for the fault? The car has 90k mi. Any thoughts are appreciated.
Old Feb 26, 2013 | 08:12 PM
Braminator's Avatar
Braminator
Yes this is the sensor after the cat. Make sure you get an OEM as they work the best IMO.
Old Feb 26, 2013 | 08:43 PM
xsmini's Avatar
xsmini
Check the wiring on it before you replace it. They are known to rub on the shielding and throw codes. If you can check the flexible joint in the exhaust header check that too. Apparently I had a small hole at the joint (couldn't even hear it leaking) that kept causing the error code. Didn't know that was the cause until the joint broke, and I had it fixed.
Nik
Old Feb 27, 2013 | 06:11 PM
northbarts's Avatar
northbarts
Thanks for the input. The SES light comes on intermittently. I'll check the wiring, but I suspect the O2 sensor is getting flaky after 90k mi. The shop manual suggests 100k change out. The OEM O2 sensor runs $285. per unit.
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
ShadyCoop
Sep 20, 2015 08:57 AM
Enjoytheride
Sep 17, 2015 12:10 PM
sirfrank
Sep 11, 2015 01:36 PM
