Anyone in Utah have belt tension tool?
If you can't find one, any long metal bar works, with a 9/16ths socket (6pt preferable) on the upper bolt as a lever (may need a shim between the frame rail), and a 1/4x1" bolt in the lower hole to push up on. Not ideal, but it gets the job done. Note: remove your dipstick first - I broke part of the yellow plastic handle in the process.
patsum
26
May 29, 2021 06:29 PM
Sterling Thompson
Sep 9, 2015 08:16 PM
