2011 MCS Manual with bunch of error codes
Old Aug 19, 2012 | 12:38 PM
mshale's Avatar
mshale
I just pulled a lengthy list of error codes from my 2011 MCS (N18 engine, manual trans) because of an ongoing issue. The issue I have is that when it's 95+ outside, and my car sits in the sun, I get a half engine power notification in the tach but no CEL and I don't actually get half power . I check that code and it tells me CCID 029. A few days ago, the engine would hesitate only the first time i pressed the accelerator. It was like the pedal did nothing, and then all of a sudden gave me full power for a split second, threw an actual CEL this time, and was back to normal. CEL went away the next day, and the dealer wasn't concerned since the CEL wasn't red...
I just pulled the error history with INPA, and the most I could get out of it was a list of hex codes. Anyone able to translate theses codes?
SPEG:
  • A87E
  • A871
  • A872
DME:
  • 29DC
  • 2C58
  • 293B
  • 2947
RDC:
  • D115
DSC:
  • D35D
  • 5E56
EPS:
  • D517
KOMBI:
  • A3B2
MASK/CCC:
  • ABEB
FRM:
  • 9CC8
KLIMA:
  • E717
Old Aug 19, 2012 | 01:12 PM
scottab36's Avatar
scottab36
If you have the P codes or MINI FC codes I could bounce them off my Bentley manual for you.
Old Aug 19, 2012 | 01:29 PM
mshale's Avatar
mshale
Thanks, scottab36, but I have no idea how to get these into the P format, and I wasn't even aware of an FC code...
Old Aug 20, 2012 | 09:44 PM
bluefox280's Avatar
bluefox280
What scanner is such? That doesn't sound like an approved MINI-protocol scanner.
All I can cross-reference is the DME (ECU logic) faults:
* MINI DTC P10D0 (0x29DC) - Charge Air Temperature Sensor, Plausibility, Cold Start: Temperature Too High
* MINI DTC P1260 (0x2C58) - Boost Pressure Control, Deactivation: Boost Pressure Build-up Blocked
* MINI DTC P10D4 (0x293B) - Coolant Temperature Sensor, Plausibility, Cold Start: Temperature Too Low
* MINI DTC P316B (0x2947) - Engine Coolant Temperature Signal Stuck
For starters, replace that Coolant Temperature Sensor (CTS); that's a known common issue that's been overhauled.
I cannot; you may want to check with Bavarian Technic to see if they can decipher the other powertain / convenience codes.
Regardless, with that many active fault codes present, I'd head to the dealer as your warranty will cover such.
- Erik
Kimolaoha
Jul 5, 2023 01:04 PM
mdutton11
14
Oct 26, 2015 01:47 PM
Zettinger
Aug 25, 2015 04:04 PM
massmini03
Aug 12, 2015 11:19 AM
oldsbear
Eastern Iowa MINIs
Aug 9, 2015 04:02 PM
