A/C Line wear from Sway Bar
Old Jun 29, 2012 | 04:24 PM
texasmontego's Avatar
texasmontego
Anyone encounter this problem? One of the A/C hose/line crimped connection is being worn by the sway bar and causing it to leak. Anyone else heard of this issue?
There is about 1/2" clearance b/w the hose and bar when the car sits normal. Seems like under hard hits that the hose is making contact with the bar.
Just wondering if anyone else has heard of this? Going to buy the hose tomorrow and replace it. (have a friend that can evac it).
Old Jul 9, 2012 | 12:59 PM
Rovy's Avatar
Rovy
Yeah I finally took mine up to the dealer (A/C lost pressure during a drive last year) to have them tell me I rubbed a hole in the hose (not sure the location atm) but they quoted close to $800 to replace. Yes I was lowered on KW3s I checked for rubbing the best I could but obliviously missed it.
Old Jul 10, 2012 | 11:42 AM
tominizer's Avatar
tominizer
I should check this too. Hmmmmmm
Old Jul 11, 2012 | 02:56 PM
texasmontego
Did the repair myself. Had a friend evac it, changing the hose took all of an hour, then had my friend recharge. Start to finish 2 hrs. Part was $110 from Momentum Mini in Houston (they matched online prices). If you can get someone to charge it, its a simple fix.
Just remove the wheel & wheel well liner and you have access to the connection. Top connection is behind the airbox after you remove it.
Def saved myself $600+ by doing it in a couple hrs.
W0TM8
Dec 19, 2019 07:50 AM
Mini7
Feb 2, 2016 07:52 PM
minimofo
Sep 9, 2015 10:29 AM
Bea5tMa5ter
Aug 27, 2015 01:42 PM
nomar116
Aug 10, 2015 11:24 PM
