Rear Brake Pads
Old Jun 10, 2012 | 08:06 AM
slimjimtell's Avatar
slimjimtell
Rear Brake Pads
My rear brake sensor came on and I checked the brake pads and the rear INSIDE pad has about 1/3 less pad than the outside pad. Is this normal for the inside to wear quicker? Because the INSIDE wore out quicker, it tripped the sensor.
I run EBC Red's. Gonna order new rears today from Way. Fronts seem to be OK.
Old Jun 10, 2012 | 08:26 AM
Chris(CA)'s Avatar
Chris(CA)
The slider pins have to be kept nicely lubed, did you check them?
I think they require high temperature copper grease.
Old Jun 10, 2012 | 08:33 AM
Tu13es's Avatar
Tu13es
+1
I had my car in for an oil change the other day and the mechanic pointed the same thing out on my car. I believe one of the pistons (pins?) got some gunk in it and therefore wouldn't retract, causing the uneven wear.
Old Jun 10, 2012 | 09:17 AM
slimjimtell
Can anyone point me where to get the instructions on greasing the pins.
Old Jun 10, 2012 | 01:30 PM
bluefox280's Avatar
bluefox280
There's some dis-assembly required like removing the caliper, but simply remove the guide pin - clean, grease, and reinstall.
- Erik
W0TM8
Dec 19, 2019 07:50 AM
jpgwinn24
Tires, Wheels, & Brakes
Aug 23, 2015 02:53 PM
jpgwinn24
R55 :: Clubman Talk (2008+)
Aug 20, 2015 06:57 PM
