Solution to oil consumption, vlv cover leak and more?
Old 02-01-2020, 11:53 AM
Lex2008's Avatar
Lex2008
Lex2008 is offline
Originally Posted by Nikola Hristov
Fjcw(factory jcw)is a jcw not a cooper s with tunning kit. 😃
I’ve inspected my engine bay and there seems to be no oil leaks except the one near the valve cover which is very very small. I will do the compression and leak down test for sure tho.
I am wondering whether or not to change my timing chain if I am doing the valve cover. There is no knocking or sounds from it, but isn’t it about time for it?
The timing chain is an entirely more complex project and the valve cover gasket is cheap, you can even reuse it if its not old. Its rubber Youll just need a lil more RTV.. So dont worry about doing one with the other unless you know for sure you need a new timing chain and tensioner/guides...which are a very expensive and laborious process.
Frixos
12-30-2019 11:24 AM
Precious_Roy
09-12-2017 06:55 PM
rzarski446
01-05-2017 08:35 AM
Db.diaz
02-13-2014 05:33 PM
ariahokas
11-11-2013 12:02 PM
Quick Reply: Solution to oil consumption, vlv cover leak and more?
