Fuel gauge not working correctly after fuel pump change
Old 04-02-2012, 01:41 PM
movieman's Avatar
movieman
movieman is offline
So, I had a fuel pump go out on me a couple of weeks ago, the replacement pump was fine, then it died on me the other day. After the car got towed to the shop and they re-replaced the pump with a dealer part, they discovered that it was out of gas. The gas gauge said it had 1/4 tank. They put gas in, and the gauge isn't reading correctly still.
Any suggestions on what this could be?
Old 04-02-2012, 03:09 PM
sbeezy's Avatar
sbeezy
sbeezy is offline
fuel gauge sending unit maybe.
Old 04-02-2012, 04:18 PM
movieman's Avatar
movieman
movieman is offline
Isn't the sending unit part of the pump?
Old 04-07-2012, 05:52 AM
NC TRACKRAT's Avatar
NC TRACKRAT
NC TRACKRAT is offline
The sending unit arm hangs on the outer shell of the pump/filter assembly. They may well have dislodged or bent it when they installed the new pump. (See REALOEM parts diagram). Take it back and tell them to fix it.
Old 07-22-2012, 08:33 PM
mernbrad's Avatar
mernbrad
mernbrad is offline
Mine did the same thing and I was told the fuel filter sending unit was bad along with the pump sending unit. The fuel filter is on the right side of the tank. I had to replace both of the parts it took a couple hours. After the replacement the tank was showing 1/4 of fuel. This was my Saturday project I haven't run a full tank of fuel yet. The up side the car runs better at idle and under normal acceleration.
Old 07-28-2014, 12:57 PM
famguy's Avatar
famguy
famguy is offline
I have the same issue after installing a new original fuel pump.
I've double checked that the arm isn't bent and is working just fine, but the fuel gauge is not working at all.
What could it be? I guess the fuel gauge itself doesn't have its own fuse?
07-16-2020 12:54 PM
sprp85
08-22-2015 06:16 AM
skippermini
08-13-2015 06:13 AM
kpl
08-11-2015 04:52 AM
bc219
08-10-2015 11:22 AM
Quick Reply: Fuel gauge not working correctly after fuel pump change
