Power Steering Leak?
Old Mar 21, 2012 | 07:14 AM
CptNemo's Avatar
CptNemo
I just bought a new to me, 03 R50 last weekend. Everything on the car checked out great not a drop of liquids anywhere and the power steering pump didnt make a noise (double checked this knowing about the probability of one being bad). Then last night as I pulled the mini out to give it an actual bath. I noticed a couple of drops of thick green fluid on the floor of the garage. Is this the start to my power steering pump going out or am I off on my diagnosis. Sugestions please.
Old Mar 21, 2012 | 06:56 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by CptNemo
...I noticed a couple of drops of thick green fluid on the floor of the garage. Is this the start to my power steering pump going out or am I off on my diagnosis. Sugestions please.
The most likely case is that both of the lines from the reservoir to the pump are leaking. There are O rings in the connections that are prone to dry out and crack. A VERY common and not a difficult replacement.
But be sure to use the correct, CHF 11s fluid if you replace the lines or top it off.
Rich
Old Mar 21, 2012 | 07:37 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Check to make sure it's P/S fluid or coolant, either one could be green.
Etrain
16
Aug 5, 2024 04:37 AM
Manny_cooper
Sep 10, 2015 11:09 AM
Aug 25, 2015 09:33 AM
JPMontes3
Aug 23, 2015 01:26 AM
minipopkart
Aug 13, 2015 05:22 AM
