'06 MCS R52 Door removal procedure
Old Mar 16, 2012 | 08:41 AM
TheBelcherMan's Avatar
TheBelcherMan
Hey all, need to remove both doors from my MINI. Trying to figure out if I remove the hinge from the door, or remove the pivot from the hinge. It looks like the pivot can be removed and would be the preferred method as to maintain alignment of the door.
I'm trying to fish new speaker cables through that very tight conduit and it only gonna happen with the doors off
Thanks in advance!
Old Mar 16, 2012 | 10:29 AM
Eric_Rowland's Avatar
Eric_Rowland
I ran wires through my doors just fine without removing them. See pics in my gallery, and step by step in my 'powerfold mirror' thread. Just disconnect the door connector, run wires from inside and through connector (after drilling out), then fish through accordion connector.
Old Mar 16, 2012 | 11:59 AM
TheBelcherMan
I looked at your gallery and that helped. What's the procedure to disconnect the door connector? I took off the single bolt and slid it back towards the cabin. The connector "cover" came off but it seems like there is another step to disconnect.
Also had a question about the picture labeled "door_conn_pwr_wires_web"
Did you have to destroy the connector? I've never looked at a good one, so I can't tell.
Thanks for your time Eric
Old Mar 16, 2012 | 12:24 PM
TheBelcherMan
Ok, I found your thread on the mirror project. You said close door halfway, then push connector forward" Are you using the car body to brace the inside connector as you push the outside connector towards the front of the vehicle?
I'm just having a really tough time trying to visualize this connector, so the two halves slide apart to unlock and then you pull it off?
Old Mar 16, 2012 | 12:34 PM
TheBelcherMan
I got it, it's sort of like the two connections for the ECU.
You guys are the best! Cheers
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
minipopkart
Aug 13, 2015 05:22 AM
PrimePower
Aug 11, 2015 12:51 PM
Red Raven
Aug 11, 2015 04:48 AM
