Is this correct
Old Mar 16, 2012 | 07:34 AM
drsimmons's Avatar
drsimmons
Is this correct
I was detailing Nimbley this morning and I opened
the bonnet and happened to see this screw with a
spring around it. It's located just beneath the dip
stick end (yellow).
It's somewhat loose, is it suppose to be loose or is
it suppose to be screwed all the way in???? What
does this screw do?
Any help would be appreciated. Thanks.
Attached Thumbnails Is this correct-dscf0001.jpg   Is this correct-dscf0002.jpg
Old Mar 16, 2012 | 08:01 AM
terpsred's Avatar
terpsred
I'm not sure what that screw does, but my 2009 has it as well.
Old Mar 16, 2012 | 08:06 AM
drsimmons's Avatar
drsimmons
I can actually shake it back and forth and get play in it. Does yours
do that also?
Thanks for replying.
Old Mar 16, 2012 | 08:13 AM
JAB 67's Avatar
JAB 67
Is it part of the headlight leveling adjustment system?
Old Mar 16, 2012 | 08:19 AM
Paleo's Avatar
Paleo
That is the locking pin for the belt tensioner. It holds the tensioner arm in the "tension free" position allowing for the belt to be removed.
Old Mar 16, 2012 | 08:25 AM
drsimmons's Avatar
drsimmons
Is it suppose to be kinda loose feeling?
Old Mar 16, 2012 | 08:35 AM
Paleo's Avatar
Paleo
Yes, it's just a pin with a spring around it, so when the tensioner arm is pulled up can be pushed through the hole in the arm and lock it in place. Once the arm is moved up slightly from the locked positon the spring pushes the pin out of the hole and releases the arm.
Old Mar 16, 2012 | 08:38 AM
drsimmons's Avatar
drsimmons
Thank you very much. I just wanted to make sure it wasn't
one of those things that might pop out on its own and !@#%
Appreciate your time.
navybsn
Oct 5, 2018 04:42 PM
honderpilot
Oct 11, 2015 06:35 AM
Fordgt4
Oct 10, 2015 10:42 AM
nomar116
Electrical
Sep 20, 2015 10:26 AM
