roll call, have you replaced your thermostat housing .
Old Feb 25, 2013 | 04:47 PM
  #101
Tu13es's Avatar
Tu13es
Joining the club on this one (09 R56 JCW). Apparently both my water pump and thermostat gasket are leaking. $900+ P&L for those two, plus a cracked drive belt. Ugh. Barely 5k out of warranty...
Old Feb 25, 2013 | 06:52 PM
  #102
mainedrag's Avatar
mainedrag
28k, Bedford NH Mini replaced my temp sensor for the fourth time! Thank Dog for the extended warrantee BMW granted me after the third sensor.
Old Feb 25, 2013 | 08:10 PM
  #103
AndresR's Avatar
AndresR
Replaced under warranty at 25k, car fans keep running at max speed on for 5 minutes after shut down
Old Feb 26, 2013 | 05:42 AM
  #104
GTSSRTJCW's Avatar
GTSSRTJCW
My dealer told me that any work they do, sans clutch, brake pads, or wearable items are covered by MINI for 2 years and 24k... I'm counting on that should my thermo housing go out again. Mine was replaced under an extended warranty I purchased through my credit union. Hate to do it, but the car may have to go when it expires in 3 years... So much fun to drive, but too expensive without a warranty~
Old Feb 26, 2013 | 07:46 AM
  #105
MikewithaMini's Avatar
MikewithaMini
'08 S at 80K under warranty (extended)
Old Feb 26, 2013 | 08:08 AM
  #106
Yakatak's Avatar
Yakatak
Drive belt?? What drive belt??
Old Feb 26, 2013 | 08:14 AM
  #107
Yakatak's Avatar
Yakatak
After I replaced mine, the indicated operational coolant temp went up about 10 degrees F and, the fan also runs a bit longer than before. I think it must be due to variability in temp sensors.
Old Feb 26, 2013 | 08:18 AM
  #108
Tu13es's Avatar
Tu13es
I think he said drive belt but meant serpentine belt. Not the timing chain.
Old Feb 27, 2013 | 11:28 AM
  #109
myR56S's Avatar
myR56S
49K miles and I just noticed a wet spot on the ground, seems to be coming from the back of the motor...
...and I just repaired my failed turbo oil supply line :(
Old Feb 27, 2013 | 12:08 PM
  #110
Yakatak's Avatar
Yakatak
Well, at least the scenery will be different. I did both of those within a couple weeks of each other too. Both just about a month out of warranty.
Jon in SC
Old Feb 27, 2013 | 12:47 PM
  #111
danigurrl's Avatar
danigurrl
It happened to my brand new 2012 MCS about a month after I bought it. Luckily, 14 months and 30,000 miles later...it's been perfect.
Old Feb 28, 2013 | 04:45 AM
  #112
Tu13es's Avatar
Tu13es
So has the thermostat housing (or water pump in my case) been redesigned? Or should I just expect to fork over ~$1k in another 50k miles when they break again?
Old Feb 28, 2013 | 09:02 AM
  #113
myR56S's Avatar
myR56S
Jon in SC
Double ouch!
Old Mar 6, 2013 | 08:02 PM
  #114
wallymango1's Avatar
wallymango1
'09 Mini S thermostat housing
Well I got the housing off in about 2 hours, (it's been a long time since I've done any extensive under the hood work on any car), and I thought that I had the procedure down. When I began to twist the housing to free it up from the return tube coming from the back of the engine I heard a crack. I had the shop finish the job. I know now that the return tube is a little fragile especially since, 1) it is plastic and 2) that plastic has been subject to large amounts of heat. I know that, looking back, I should have been more careful. But I can't help but having no recollection of ever having to be so "dainty" working under the hood of any car that I've ever owned. Plastic, especially those parts directly connected to the engine and so close to said engine, really does not belong there. Just my opinion. I guess that this is something that I can look forward to further down the road, whether with this car or if I happen to chose to buy another Mini. The "check engine light" has gone off now for over a week after the on again, off again series. We'll see what the future holds.
Old Mar 11, 2013 | 09:03 AM
  #115
kcwilson's Avatar
kcwilson
im aabout to replace mine here in the next few weeks
im bout to hit 69K miles on my yellow mini. i ordered the parts myself and i'm getting my personal mechanic (THAT I'D TRUST WITH MY LIFE,..AND MY COOPER) to install them I was quoted $392 for the replacement at our local firestone. i ordered the parts for about $80.00 total, and labor shouldn't be too bad
Old Mar 11, 2013 | 09:15 AM
  #116
n2hcky's Avatar
n2hcky
Just spotted the leak this weekend on my '08 justa clubman 88k. Getting the part from my buddy at BMW for $86. Gonna DIY it. Shouldn't be any problems from what I read.
Old Mar 19, 2013 | 02:38 PM
  #117
ucdinh's Avatar
ucdinh
Had mine replaced Cooper 08 S @ 55k miles. I had a puddle of coolant on the floor of my garage after coming home from work the previous night. I had it towed to my buddies shop and changed it out for about $200.00
Old Mar 20, 2013 | 05:46 AM
  #118
myR56S's Avatar
myR56S
Originally Posted by wallymango1
...when I began to twist the housing to free it up from the return tube coming from the back of the engine I heard a crack.
Thank you wallymango1, I will keep my patience about me when working with the rear return tube!
I replaced the water pump last Saturday, I am replacing the thermostat housing this Saturday. Should have done them together, LOL. Where one fails expect the other to follow soon. And at the price of coolant ($25 per gal) it makes sense to just do the two together.
Does anyone know if the thermostat housing was updated like the water pump (metal used now?).
Old Mar 20, 2013 | 09:06 AM
  #119
ucdinh's Avatar
ucdinh
It is still plastic, I didn't see a metal housing listed anywhere.
Old Mar 20, 2013 | 09:14 AM
  #120
dwebber18's Avatar
dwebber18
The thermostat is definitely still plastic, mine has been running well in that regard since I changed it a couple months ago. But yes be extremely careful with the return pipe, there is a metal clip on the back of the thermostat the connects to the return pipe if you don't remove it the pipe and thermostat will come out together. That happened to me and even though I didn't hear a crack there was a little piece of plastic missing from the end and the pipe is tough to find. I had to order it from the dealer for $100 and a weeks wait. It took me almost 3 hours to get the return pipe put back in because it just pushes in place and you have to hold it there while hooking up the thermostat and it's pretty tough. Don't get me started on all of the other problems I've had over the last 6 months though, this was the tip of the iceberg.
Old Mar 23, 2013 | 02:48 PM
  #121
myR56S's Avatar
myR56S
Just finished the thermostat housing. Not a horrible job at all! Did it in under 3 hours. The hardest part was removing the lowest pipe that feeds the turbo. Easy stuff.
I was super gentle with the return pipe too. I would rather do this job again than have to have done the water pump I did last weekend.
Old Mar 24, 2013 | 11:04 PM
  #122
krim's Avatar
krim
Just had my 2nd Thermostat replaced under warranty, (CEL SGII Codes U3FFF, sometimes P0597, stuck open). The first was a cracked housing, replaced late '11.
Was advised by SA that the thermostat is covered under the 7yr/70mi emissions warranty. Since the housing and the thermostat are one part, if the housing is cracked, it might be under warranty for some of you reading this.
Old Mar 25, 2013 | 08:51 AM
  #123
myR56S's Avatar
myR56S
This would have been great news last Friday
Oh well, the experience gained from this repair is priceless.
Old Mar 25, 2013 | 05:29 PM
  #124
krim's Avatar
krim
just took her in Friday.
Old Mar 26, 2013 | 06:45 AM
  #125
RGLARRY's Avatar
RGLARRY
I have just short of 80K miles. My mechanic sees some residue but I have not seen coolant leaking issues. What symptoms did you have before replacing the thermostat and housing? I went to the dealer and they said there is no issue. Probably just a bad independent mini mechanic just want to make sure.
