Hamster wheel noise under bonnet
Old Jan 2, 2012 | 09:17 AM
Burno's Avatar
Burno
Aggravating loud noise coming from engine during idle. Goes away when i steady rev around 1500 rpm at a light. Sounds like a hamster wheel..Squeek , squeek , squeek...ect..Pretty loud when a car is next to me LOL...Would an alternator with bad bearings do this or would the tensioner wheel be going bad...125K on the odometer , I had it running in the driveway yesterday and sprayed some water in the direction of the alternator area and the noise stopped for about 5 min...dont like driving it now with all that squeaking. sounds like a junker...the belt is only about 2 yrs old and I dont really put my foot into it anymore....Tried spraying a little bit of WD inbetween the housing and pully of the alternator but that didnt help.....Driving me crazy... any help would be appreciated
Old Jan 2, 2012 | 09:44 AM
Blackbomber's Avatar
Blackbomber
Aren't these cars powered by hamsters? I think this is normal.
All kidding aside, you are on the right track. My guess would be the tensioner wheel bearing. Not too bad to replace on an R50. I use a mechanics stethescope to narrow down the origin of these sounds. I can't tell you how many tensioner pulleys I've replaced for noise (and self-destruction - thanks Saab). I have never replaced an alternator or waterpump for noise, though. Doesn't mean you don't have a bad one. Just the law of averages in my experience leads me to suspect the idler.
Old Jan 2, 2012 | 12:32 PM
ZippyNH's Avatar
ZippyNH
My suggestion...remove the belt, and check all the pullies....find the right one...replace...could be the idler...alternator, tennsioner, ac, or in some cases the oil leaks out of the sc/waterpump pto, the gears run dry, and it squeels as it selfdestructs on an s...
Find the issue...then fix it.
And 2 years on the belt (non oem) is about howlong they last of you have a pully reduction due to the smaller diameter of the contact are....
Old Jan 2, 2012 | 12:34 PM
ZippyNH's Avatar
ZippyNH
Ps...
Most suggest a new bely YEARLY with a 17%.
Might ne just the belt....
Old Jan 6, 2012 | 05:40 PM
Burno's Avatar
Burno
Thanks guys it was the tensioner after all ....a litle WD and its gone for a day or two...but will change ASAP....THANKS
maestro39
Oct 27, 2015 02:38 PM
theblackfalcon
Oct 11, 2015 09:49 AM
Mikal68
Aug 13, 2015 07:10 AM
bctf1
Aug 6, 2015 12:55 PM
