Removing Harmonic Balancer
Old Sep 18, 2011 | 03:31 PM
mrbean's Avatar
mrbean
Can anyone recommend a tool for the job, or should I just break down and get the "proper" tool the dealerships use?
Also, on a side note, I went to go replace my timing chain cover gasket. Since I couldn't get the crank pulley off, I removed this instead. I figured "hey, while I'm under here might as well."
The sucker was leaking oil, so at least the day wasn't a total waste.
Old Sep 18, 2011 | 06:36 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Look at the DIY threads there are some how to directions using a puller from advance auto or something like that.
Old Sep 18, 2011 | 07:22 PM
jhiggs26's Avatar
jhiggs26
Looks like a late blower so you'll need 3 M6 bolts at least 65mm long and use with generic crowsfoot puller. Get a M12 X 1.75 X 40mm long and hack off the head to use as a thread protecter(central puller bolt can thread against this). Make sure everything is square and pull away....
Jeremy
Old Sep 18, 2011 | 08:00 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by mrbean
Can anyone recommend a tool for the job, or should I just break down and get the "proper" tool the dealerships use?...
Where do you live? I have one in Northern New Jersey.
Rich
Spank
11
Apr 9, 2020 02:23 PM
cw40342
Oct 6, 2015 05:07 PM
Lex2008
Aug 31, 2015 12:12 PM
D3nZem
Aug 30, 2015 07:05 AM
greekzilla
Aug 23, 2015 03:44 PM
