Rear Brake Wear
Old Aug 25, 2011 | 08:37 AM
ghas's Avatar
ghas
Rear Brake Wear
I have an R50 with 60,000 miles on the original brake pads. The inside rear pads are about gone but the fronts still are 5-6mm thick. Is it normal for the rear pads to wear faster than the front? This has never happened on any other car I've owned.
Old Aug 25, 2011 | 09:58 AM
quikmni's Avatar
quikmni
On my R53 the rears wore out first.
Old Aug 25, 2011 | 10:15 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Either you folks are driving with the handbrake on or perhaps dragging/out of adjustment or there is something wrong with the brake bias/proportioning. Fronts should always take more wear than the rears.
Old Aug 25, 2011 | 11:38 AM
quikmni's Avatar
quikmni
I agree that the fronts should wear out before the rears but I know that on my 2003 MCS that the rears wore out first and there was nothing wrong with the rear brakes. I have seen many posts where people have had the rears wear out before the fronts.
I suspect there are a few reasons for this:
- Softer pad material in the rear
- Much smaller pad surface area for the rear pads
- Thinner pad material on the rear
- Rear pads/rotors get very hot under hard use
- Rear caliper pistons tend to stick a little causing a little drag on the rotor
Old Aug 25, 2011 | 11:43 AM
ke3ee's Avatar
ke3ee
Our 2006 S with 23k has already gone thru a set of rear pads and the front were at 75% when I did the rears.
Old Aug 25, 2011 | 12:15 PM
ghas's Avatar
ghas
OEM pad material
I did notice that the front OEM pads are made by Jurid and the rear OEMs by Ferodo so maybe the pad material is a key difference in wear.
Toolman
Jan 20, 2016 06:50 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
jpgwinn24
Tires, Wheels, & Brakes
Aug 23, 2015 02:53 PM
jpgwinn24
R55 :: Clubman Talk (2008+)
Aug 20, 2015 06:57 PM
