Valve cover gasket leak + odd issue...
Old Jul 18, 2011 | 04:56 PM
ryangschultz's Avatar
ryangschultz
3 problems...
  1. I just got my 2004 MC and was checking out the engine bay. I realized there seems to be a lot of oil residue around the base of the valve cover that seems to be dripping down below the car as well. Is this just a typical valve cover gasket leak?
  2. Next, there is oil residue around one of the spark plug holes, and when I took out the ignition wires, there was some oil reside in one of the holes as well. What's going on...it's above where all the oil leaks could happen right?
  3. There is an awful lot of, what seems like oil, residue on the power steering reservoir...what does this mean?
Appreciate the help!! pics are in order of problem
Attached Thumbnails Valve cover gasket leak + odd issue...-photo-1.jpg   Valve cover gasket leak + odd issue...-photo-2.jpg   Valve cover gasket leak + odd issue...-photo-3.jpg
Old Jul 24, 2011 | 10:28 AM
Duvivr6's Avatar
Duvivr6
Power steering is a common thing all the BMW I have had throughout the years do the same....
My valve cover gasket looks exactly like yours :(, I am planning in replacing it soon!
Old Jul 24, 2011 | 10:37 AM
ryangschultz
Good to know about the power steering filler.
But turns out I don't have a leak! About a week later and I haven't lost any fluid, just cleaned it off and filled it. I just bought it so I guess the previous owner was just lazy and couldn't use a funnel! So try that first!
Old Jul 24, 2011 | 04:42 PM
HRM's Avatar
HRM
For the cover gasket, I usually just try and give the bolts a tiny twist to make up for any shrinking that the gasket has undergone. In the old days the gaskets got brittle and too much tightening would make the leak worse. Having seen the gasket it looks to me like that is not very likely to happen, but still I would just snug them down a bit.
Old Jul 24, 2011 | 06:15 PM
ryangschultz
Hmm, well I bought a new gasket for it, they're very inexpensive. But I will keep that in mind for the future, I'm sure it's due for a change anyway, I don't know if it has ever been replaced. Good tip!
Old Jul 24, 2011 | 06:56 PM
HRM's Avatar
HRM
Check the bolts too before the day of the transplant. My rear ones were so rusted a 7mm socket worked fine (well, with a hammer). Some time in the past salt water must have splashed there and they were totally shot. I ordered factory new ones for around $50, but mine were totally unusable. Just a heads up in case you have the same NE rot.
Old Jul 24, 2011 | 07:08 PM
ryangschultz
Thanks, fortunately this is a NC Mini so it doesn't have a spot of rust on it. I can't believe what great condition it's in compared to all these NY cars up here.
Old Jul 25, 2011 | 05:24 PM
Duvivr6's Avatar
Duvivr6
Good to hear let me know how does that change go for ya!
Old Jul 25, 2011 | 07:55 PM
ryangschultz
I will thanks!
bobbiemartin
Jan 20, 2016 05:28 PM
PaulWalliDumali
Aug 21, 2015 04:46 PM
azntaiji
Aug 13, 2015 03:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
eliseo1981
Aug 6, 2015 05:00 AM
