Strange suspension inconsistency
Old Jun 7, 2011 | 10:44 AM
Yardley's Avatar
Yardley
I was checking the wheel gap on my 2010 Mini Cooper S and noticed that it is not consistent on all wheels. The front right and rear left have a wheel gap of three fingers, while the front left and rear right have a wheel gap of 4 fingers. Car only has 7k miles, any thoughts on this?
Old Jun 7, 2011 | 01:30 PM
schatzy62's Avatar
schatzy62
First make sure it is on a perfectly FLAT surface. If it is in a parking lot or drive way bake where there is not a low spot before trying testing. They DO NOT test with your fingers test with a tape measure from the ground to the arch they should be with in 0.25" (1/4") from side to side. But again it must be a good flat surface.
Old Jun 8, 2011 | 06:17 AM
slinger688's Avatar
slinger688
Mine is the same. Not sure why.
Old Jun 8, 2011 | 06:19 AM
slinger688's Avatar
slinger688
Btw, measure from the middle of the wheel hub to the edge of the fender. This way you do not have to worry about the uneven ground that much.
Old Jun 8, 2011 | 09:13 AM
Jim Michaels's Avatar
Jim Michaels
Wouldn't parking on a side slope place a bit more weight on the lower side, compressing those springs a bit more? In that case, the lower side measures should be a little less whether measured from the ground or from the hub center.
Old Jun 8, 2011 | 10:52 AM
slinger688's Avatar
slinger688
Uneven ground not slopes or curbs or jack stands.
vulkandino
Oct 31, 2015 08:29 PM
GAT
Oct 4, 2015 07:27 PM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
Emnotek
Sep 29, 2015 07:37 AM
