Strut mount replacement tips
Old Jun 15, 2017 | 11:58 AM
  #26
Lex2008's Avatar
Lex2008
Hey guys, I did this job more than 2 years ago and then recently the front struts started bouncing inside the knuckle receiver because the nut came lose. I tightened it for the second time and used Loctite Red.
I noticed this time that the bolt was threaded at both ends which makes no sense because the knuckle or carrier isnt threaded (OR IS IT?). 150k miles on my 2008 R56 S and this was the first new set of suspension parts.
I'm referring to #3 and #4 in schematic. The bolt shown seems threaded at one end but mine are threaded at both ends with a smooth section in the middle. Are your knuckles/carriers threaded or simple nut/bolt situation?
Old Jun 15, 2017 | 12:03 PM
  #27
It's threaded at one end last time I looked at it
R53
Old Jun 15, 2017 | 12:31 PM
  #28
Lex2008's Avatar
Lex2008
Well that's interesting. No wonder mine came lose so easily. The threads on my unit are long rusted away. I may need to put in a helicoil or tap new larger threads and go with a 19mm. Or maybe just use a jam nut as well as loctite.
Old Jun 15, 2017 | 12:34 PM
  #29
Racingguy04's Avatar
Racingguy04
I think the R56 isn't threaded. The R53 is threaded. Often when R53 owners have to drill out a broken bolt, they'll just put a longer bolt in with a nut, but I think the R56 was designed to use a nut instead of a threaded steering knuckle.
Old Jun 15, 2017 | 12:38 PM
  #30
Lex2008's Avatar
Lex2008
OOPS sorry I didnt realize I was in the Gen 1 section. Sorry guys. Thanks for the info Racingguy04.
Old Jun 15, 2017 | 12:39 PM
  #31
R56:
Does not look threaded.
Old Jun 15, 2017 | 12:42 PM
  #32
Lex2008's Avatar
Lex2008
thanks sir.
Old Jun 16, 2017 | 10:24 AM
  #33
Welcome.
Old Sep 29, 2018 | 06:26 PM
  #34
Mineeee's Avatar
Mineeee
Zombie thread revival again
I'm attempting to replace a strut mount and noticed my CV Joint now looks like this. It was already on the to do list (or at least the "get someone else to do" list), but does this look like its popped out of place now?
CV joint
Trying to figure out why Im having such a hard time getting the knuckle back on the end of the strut.
Thanks in advance!
Old Sep 29, 2018 | 08:04 PM
  #35
Lex2008's Avatar
Lex2008
CV joint
Thanks in advance!
It's hard for me to tell using my phone but it looks like you tore the boot. Am I seeing grease on the shaft? If so, you pulled it out and it needs to pushed back in bit you're gonna need a new boot, CV joint grease and clamps. I did a thread on how to change this. Look it up.
it's not hard. Just messy.
Old Sep 30, 2018 | 07:19 PM
  #36
Racingguy04
It looks to me like you need to push the axle back in some. Getting the strut back into the knuckle is a bit of a bear. It helps to have another set of hands to help keep everything lined up. A knuckle spreader (or a big screwdriver) to help open the knuckle helps too. My technique by myself is to put my floor jack under the hub/control arm, get it all lined up, and hold it with one hand, while i pump my floor jack. You don't want to force it, and it becomes obvious if it's not lined up, but that's how I do it.
You might also just make sure that your replacement struts are the same diameter as your originals. I want to say I remember someone getting a bad batch of struts that were just big enough to be impossible to go in the knuckle.
Old Sep 30, 2018 | 07:57 PM
  #37
Lex2008's Avatar
Lex2008
It looks like he tore the end of the boot off when he pulled the shaft out of the joint. The shaft is out too far out, that's why nothing lines up. He needs to replace the boot, at which point the shaft will be back inside the joint and everything will line up.
Old Oct 3, 2018 | 05:30 AM
  #38
Mineeee's Avatar
Mineeee
Thanks for the help and advice, I managed to get everything back together, nothing seemed torn. Once I got the strut in place and the knuckle back on with some judicious use of the jack everything kind of fell back in place and it drives OK, but replacing the CV joints has moved up the "to do" list for sure.
Old Oct 3, 2018 | 09:10 AM
  #39
Lex2008's Avatar
Lex2008
I'm looking at your pic using my computer rather than my phone and its obvious that you tore the end of the CV boot. The grease will start oozing out until its all dry.
You're gonna need to take it off and repair it my friend.
Old Oct 3, 2018 | 11:21 AM
  #40
Mineeee's Avatar
Mineeee
Will do
Toolman
Jan 20, 2016 06:50 AM
maestro39
Oct 27, 2015 02:38 PM
JPMontes3
Aug 23, 2015 01:26 AM
sabjcw
Aug 14, 2015 07:40 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
