2011 washer nozzle weeping...
Old May 10, 2011 | 06:02 PM
  #26
Roundel's Avatar
Roundel
Mine does it too, will take it in
Old May 11, 2011 | 05:20 AM
  #27
zeiker's Avatar
zeiker
Thanks for the follow up and pix, Pheatton!
Appreciate the info.
Old May 11, 2011 | 10:03 AM
  #28
pheatton's Avatar
pheatton
Glad I could help.
So its been about two weeks now and nothing leaking still.
Old May 11, 2011 | 11:23 AM
  #29
VYPUR's Avatar
VYPUR
Man I gotta take mine in and hopefully I will have the same luck as you
  #30
NYC-JCW's Avatar
NYC-JCW
My 2011 JCW does it too... usually after a spirited ride where the turbo heated up a bit..
But he waits until I walk away...doesn't want me to see him cry..I guess he misses me...
Old May 12, 2011 | 07:27 AM
  #31
darthhen's Avatar
darthhen
Hahaha.....yeah....that's a good line.
Old May 12, 2011 | 07:32 AM
  #32
darthhen's Avatar
darthhen
For some reason, I'm not seeing the weeping anymore. Maybe I need to drive it harder!!!!
Old Jul 3, 2011 | 11:10 PM
  #33
Eclipse11S's Avatar
Eclipse11S
So has everyone taken it to the dealer for the checkvalves and it solved the problem???
Mines does it when driving for awile and when it's really Hot out.
Old Jul 4, 2011 | 09:11 PM
  #34
Eclipse11S's Avatar
Eclipse11S
^^^ BUMP
Did the Valve Checks Work???
Old Jul 4, 2011 | 09:19 PM
  #35
cub4bearindiana's Avatar
cub4bearindiana
yes it did for me.. so far about two weeks with it and no visible problems.. 2011 MCS here.
Old Jul 4, 2011 | 09:55 PM
  #36
Eclipse11S's Avatar
Eclipse11S
Thanks for the reply.
Did they add them near the nozzles ?
Anybody else???
Old Jul 5, 2011 | 10:04 AM
  #37
pheatton's Avatar
pheatton
Since I have had mine done not issues since.
Old Jul 5, 2011 | 06:46 PM
  #38
cub4bearindiana
Anybody else???
yes right behind nozzles.. if I had these parts I could do it on my own..
Old Jul 6, 2011 | 08:42 PM
  #39
RJKimbell's Avatar
RJKimbell
I have a 2008 MC and just noticed tonight that I had had Weepy Washer Jets, it was dried on??!! I took some Speed Shine and a MF Towel and wiped it up. I use 303 Instant Windshield Washer Tablets so it didn't stain, but I was surprised to find it. Think I might have to talk to my SA about this!!
Old Jul 7, 2011 | 11:22 AM
  #40
seepw's Avatar
seepw
Anyone PLEASE post a part number to the valves that were used for this fix? I am stationed in Germany. I have taken my Mini into the shop 3 times for this issue. The problem apparently is that Mini here in Europe supposedly have had no complaints on this issue and have no idea what part # it is. They ordered check valves yesterday from a 3 series but could not make them fit.
Apparently these check valves you all had installed are not an actual listed Mini part so any help would be greatly appreciated!
Old Jul 7, 2011 | 11:34 AM
  #41
cub4bearindiana
Don't remember part number right away but it is the same check velve they use for rear windshield wiper, it is ONE WAY valve, and u just need two of them. That's it.
Old Jul 7, 2011 | 11:37 AM
  #42
cub4bearindiana
Part number: 61-68-8-229-249
Old Jul 7, 2011 | 11:57 AM
  #43
seepw's Avatar
seepw
Halleluah!!! and that is the actual mini part # from the dealer? I really appreciate your response. This will save me from snapping tomorrow when they still tell me there is no fix...
Old Jul 7, 2011 | 06:09 PM
  #44
zeiker's Avatar
zeiker
Weeping Nozzles - TECHNICAL BULLETIN
Just came from Nashville Mini.
Not only have they heard of this issue, and have actually installed the two check valves that mitigate / eliminate weeping, they actually had and showed me the technical bulletin describing the issue and the fix.
If any other dealers give you the run-around, or are not aware of this, have them call their counterparts (pardon the pun) in Nashville.
It is also a warranty issue, so they will fix it for me at no cost. They did not have any of the valves in stock, so they had to order them. Will let you know how it went after installation, though I don't suspect any further issues.
(Kudos and shout-out to Nashville Mini)
Old Jul 7, 2011 | 07:08 PM
  #45
RJKimbell's Avatar
RJKimbell
I've got some other issues that I want looked at on Molly, her 4yr. Warranty will run out in April and she usually sees the Dealer every 6mo. anyway but I didn't want to wait 'til October, so we'll take her in sometime next week.
Old Jan 2, 2012 | 04:30 PM
  #46
cgaubuchon's Avatar
cgaubuchon
Not to revive this thread but any chance you have a SIM on your invoice zeiker? Or anyone for that matter? I have the same issue and need some direction/persuasion for the dealer to fix it.
Old Jan 2, 2012 | 05:24 PM
  #47
pheatton's Avatar
pheatton
I can look it up on my invoice when I get home.
Old Jan 2, 2012 | 06:52 PM
  #48
cgaubuchon's Avatar
cgaubuchon
Awesome, thanks
Old May 7, 2012 | 03:51 PM
  #49
minimini482's Avatar
minimini482
any update on that TSB number by chance? my 2010 has done this since new (when the engine warms up they cry and cry... so annoying). I'm going back on Friday to have the dealer try again - last time they just replaced the nozzles and that didnt do anything to fix. Please advise.
Old May 7, 2012 | 05:33 PM
  #50
cccplus's Avatar
cccplus
not sure if this help.
i had leaking washer fluid from the rear wiper. it would leak when parked in the sun/hot temperature. fixed it with the advice of some members here. there's a past post that suggest draining the dealer fluid, all of it, out. then put some distilled water in and drain that out again. refilled it with 50/50 mixture of distilled water and washer fluid. that solved my problem. no need to waste my time at dealer. good luck
