Headlight Alignment Question
Old Apr 4, 2011 | 02:52 PM
36rodder's Avatar
36rodder
From: I live in Webster, NY (just east of Rochester)
I can't seem to get my headlight alignment correct on my '02 MCS. If I adjust my low beams correctly, my high beams are in the trees. If I get the high beams right my lows are practically shining on my bumper. I have looked though my Bentley manual and they just call out the left right / up down adjustment of the housing but I can't find anything on adjusting the relationship between the high & low beams. Is this adjustable? Any idea on how to fix?
Old Apr 4, 2011 | 03:46 PM
Capt_bj's Avatar
Capt_bj
are you doing this because you changed the bulbs? Reason I ask is I had a similar problem when I changed a set of bulbs and they were not correctly seated in the sockets.... If not properly aligned and flush in the sockets they don't line up to the reflectors correctly. I had one low beam going off to never never land until I found the problem and reseated it. Mine was an 02 as well . . . the clip snapped down fine, but the bulb was not flush in the holder.... as I recall there is an alignment tab that you need to ensure drops into a slot . . . 02s were a lil different from later years in this regard. All was fine b4 I changed the bulbs so I knew I shouldn't need to actually mess with the light unit's settings....
Old Apr 4, 2011 | 04:42 PM
NightFlyR's Avatar
NightFlyR
+ 1 on what the Capt said, also different bulbs throw different patterns, took me over a week to get mine right adjusting them everynight.
Old Apr 8, 2011 | 03:42 AM
Goop's Avatar
Goop
Do the adjustment screws adjust the daytime running lights or the xenon lights? Which screw does what? Looks like the inboard screw adjusts up/down according to the manual. Correct?
Alkaidovich
Jan 30, 2021 01:35 AM
AZN Optics
Accessory Products
Aug 21, 2015 02:03 PM
AZN Optics
Aug 21, 2015 02:02 PM
Bennyboy
Aug 18, 2015 07:28 AM
